IMX8 mini LPDDR4 Nanya compatibility
Bestsy
Hi..
We produced a board with the imx8 mini MIMX8MM6CVTKZAA and the LPDDR4 Nanya NT6AN512T32AV-J2.
We are not be able to reach the 3000MT/S but only 2400MT/S.
The pcb layout seems ok, is there any known incompatibility?
Many Thanks.
Bestsy
ok, many thanks...
Bestsy
ok, many thanks...
Bestsy
Ok thanks. Do you have a "i.MX8MM (m845) DDR Controller Configuration Spreadsheet" ,the excel files, that can work with this memory?
I don't know if anyone has used this configuration IMX <--> LPDDR4 Nanya and has a working excel file...
Many thanks.
JosephAtNXP
Our teams hasn't validated the Nanya memory as you saw, that leads to the absence of any Nanya RPA configs, you should do the configuration,
Thank you for your understanding,
Joseph
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
As the DDR is currently working, I wouldn't doubt of compatibility, also, seems that your memory has the features to be compatible with 8M Mini.
Make sure to review this post so you won't miss anything.
Seems a configuration / traces optimization to me.
