IMX8 issue】
IMX8 issue】
1,770件の閲覧回数
gravity_one
hello,
i use mcimx8-8x-bb ,linux kernel is started,USB connection is normal with USB flash drive,and can read data。
but connect to the computer, the computer(win10) does not have any prompt.
usb cable is fine,because it connect debug is ok,can print info。
3 返答(返信)
1,698件の閲覧回数
Rita_Wang
If you are use theMCIMX8QXP-CPU CPU board, here you need to change the boot mode to download mode, then you can see the board detect when you connect your board to PC.
1,698件の閲覧回数
gravity_one
mirco USB can download image with UUU tools?
switch :serial mode,but mirco USB connect PC ,PC no detect device。
i use type-C can download image with UUU tools。
1,698件の閲覧回数
Rita_Wang
The Micro USB for UART debug not download images. USB-OTG is for downloading. Yes, type-C can download image with UUU tools.
