IMX8 i2c slave eeprom clock stretching
2,400件の閲覧回数
MJaroc
Im using IM8MM development board as slave eeprom emulator (i2c-slave-eeprom module). Im observe a long clock streching after master's request to my board. Sometimes its run normally, but usually looks like this:
I dont now why driver need 340 us stretch. I try to disable read from file in user-space and send random data from module but it stil need stretch.
 I need to speed-up this driver, because my master doesnt support that long stretch.
Running system:
Linux visionsom-8mm-cb-std 5.4.24-lts-somlabs_imx_5.4.24_2.1.0+gd4858bce452f #1 SMP PREEMPT Tue Feb 7 11:14:29 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
ラベル(3)
2,367件の閲覧回数
MJaroc
how can i disable clock stretching in controler? Is this even posible?
2,379件の閲覧回数
AldoG
I see that you're using a SOMLABS BSP, I would suggest to contact them regarding this issue you’re seeing.
Aldo.
