Thanks!
Using jailhouse hypervisor to load two custom images in imx8mqevk. Not getting any breakthrough to display the second image of non-root cell. Can you help on the scenario or steps for partitioning the same display screen for both images?
I do not found the official released BSP you are used 5.4.51. As we do not have the example or document for your need, here I found the code and i.MX Virtualization User's Guide document do help for you:
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
Thanks!
Does steps available for 5.4.24 bsp to partition display for two OS. Can you suggest more info on the same? I could see jailhouse primary root cell Linux UI is up but not getting how to make non-root cell Linux UI up. Is there any way other than partitioning of display, possible to achieve by using two display screen?
