[IMX8] CSI Fencing Timeout
6,544 次查看
khaledbalbaa
In the APIs MIPIDeinit and MIPIEnable I remarked that we are counting from 0 to 10,000,000 after  setting the register PHY_FENCE_CTRL waiting for the register PHY_FENCE_STATUS to be set to the same value as the CTRL register
As we know, this register is responsible for the virtual CSI channels and in our case we would like to not have any virtual channels, so we are setting the CTRL register to 0x0F and waiting for the status register to be also 0x0F, but we are waiting to the end of the timeout and the register still the same (0x00)
Questions:
1. Am I using the correct value to set the CSI with no virtual channel?
2. Why am I receiving a timeout?
3. Can the status register take this much time between the CTRL register write and the status register setting? Or this timeout could be reduced?
9 回复数
6,518 次查看
khaledbalbaa
Sorry forgot to mention it
We are working on IMX8DX processor
6,506 次查看
khaledbalbaa
@joanxie I am working with I.MX8 DX processor as mentioned
6,440 次查看
joanxie
sorry for missing this message, how about now?
6,431 次查看
khaledbalbaa
@joanxie
Still having the same question actually
The register I am asking about is named STREAM_FENCING_CONTROL, offset 0x48 in CSI registers
6,404 次查看
joanxie
got the reply from the expert team:
"The stream_fencing is used to tell the MIPI CSI2 stop data transfer to pixel link.
For example, software can write "Fence VC0" to STREAM_FENCING_CONTROL register, then after MIPI CSI2 stops to transfer VC0 data to pixel link, the status "VC0 is fenced" can be read from STREAM_FENCING_STATUS register.
MIPI CSI2 reset can recover it.
6,399 次查看
khaledbalbaa
Hello @joanxie
Thanks for the reply, but I think you have missed some of my question
My question was:
Questions:
6,346 次查看
joanxie
I found another register named "Ignore Virtual Channel Register", the default is 0, which mean can accept all of VC, how about setting this to 1 since you don't want o use any VC
6,511 次查看
joanxie
what CTRL register do you mean? PHY_FENCE_CTRL?? I couldn't find this register from the reference manual, could you tell me how you decide the value of these registers?
6,522 次查看
joanxie
what processor are you talking about? imx8qm?
