IMX6ULL-boot eMMC error
2,061件の閲覧回数
duyhai
i had this problem when starting with imx6ull custom board. Can someone assist me in debugging? i use boot from sd card.
[ 2.390705] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.408586] NET: Registered PF_LLC protocol family
[ 2.416004] NET: Registered PF_INET6 protocol family
[ 2.425888] mmc0: new ultra high speed SDR104 SDHC card at address 5048
[ 2.434753] Segment Routing with IPv6
[ 2.438762] In-situ OAM (IOAM) with IPv6
[ 2.445077] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[ 2.450082] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.503768] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.512071] NET: Registered PF_PACKET protocol family
[ 2.517364] can: controller area network core
[ 2.522305] NET: Registered PF_CAN protocol family
[ 2.527492] can: raw protocol
[ 2.530863] can: broadcast manager protocol
[ 2.535284] can: netlink gateway - max_hops=1
[ 2.540196] Bluetooth: RFCOMM TTY layer initialized
[ 2.545566] Bluetooth: RFCOMM socket layer initialized
[ 2.550885] Bluetooth: RFCOMM ver 1.11
[ 2.555008] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.560678] Bluetooth: BNEP filters: protocol multicast
[ 2.566199] Bluetooth: BNEP socket layer initialized
[ 2.571381] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.577752] Bluetooth: HIDP socket layer initialized
[ 2.583542] lib80211: common routines for IEEE802.11 drivers
[ 2.589932] Key type dns_resolver registered
[ 2.669736] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.719320] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.725912] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 2.777985] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.784696] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 2.832781] Registering SWP/SWPB emulation handler
[ 2.841005] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.847654] I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 2.856442] Loading compiled-in X.509 certificates
[ 2.903550] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.910166] I/O error, dev mmcblk0, sector 3 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 2.962080] mmc0: Tuning failed, falling back to fixed sampling clock
[ 2.968730] I/O error, dev mmcblk0, sector 4 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.020074] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.026671] I/O error, dev mmcblk0, sector 5 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.078428] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.085067] I/O error, dev mmcblk0, sector 7 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.093534] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 3.144103] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.193653] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.243151] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.292695] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.299319] I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.350780] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.357432] I/O error, dev mmcblk0, sector 1 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.408416] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.414970] I/O error, dev mmcblk0, sector 2 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3.465839] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.514801] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.563800] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.612750] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.661769] mmc0: Tuning failed, falling back to fixed sampling clock
[ 3.668329] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 3.675615] mmcblk0: unable to read partition table
[ 3.708989] imx_usb 2184000.usb: No over current polarity defined
[ 4.326012] mxs_phy 20c9000.usbphy: Data pin can't make good contact.
[ 4.342003] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 4.347056] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 4.384151] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 4.390078] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 4.398486] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.405999] usb usb1: Product: EHCI Host Controller
[ 4.411084] usb usb1: Manufacturer: Linux 6.1.36+g04b05c5527e9 ehci_hcd
[ 4.418006] usb usb1: SerialNumber: ci_hdrc.1
[ 4.423450] hub 1-0:1.0: USB hub found
[ 4.427450] hub 1-0:1.0: 1 port detected
[ 4.434488] imx_thermal 20c8000.anatop:tempmon: Commercial CPU temperature grade - max:95C critical:90C passive:85C
[ 4.449321] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.461562] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.468663] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.477710] ALSA device list:
[ 4.480701] No soundcards found.
[ 4.484326] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 4.493615] /dev/root: Can't open blockdev
[ 4.497948] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -6
[ 4.505978] Please append a correct "root=" boot option; here are the available partitions:
[ 4.514492] 0100 65536 ram0
[ 4.514508] (driver?)
[ 4.520629] 0101 65536 ram1
[ 4.520637] (driver?)
[ 4.526834] 0102 65536 ram2
[ 4.526845] (driver?)
[ 4.532958] 0103 65536 ram3
[ 4.532967] (driver?)
[ 4.539161] 0104 65536 ram4
[ 4.539172] (driver?)
[ 4.545324] 0105 65536 ram5
[ 4.545333] (driver?)
[ 4.551447] 0106 65536 ram6
[ 4.551455] (driver?)
[ 4.557592] 0107 65536 ram7
[ 4.557601] (driver?)
[ 4.563762] 0108 65536 ram8
[ 4.563772] (driver?)
[ 4.569886] 0109 65536 ram9
[ 4.569894] (driver?)
[ 4.576029] 010a 65536 ram10
[ 4.576039] (driver?)
[ 4.582238] 010b 65536 ram11
[ 4.582247] (driver?)
[ 4.588491] 010c 65536 ram12
[ 4.588502] (driver?)
[ 4.594726] 010d 65536 ram13
[ 4.594734] (driver?)
[ 4.600933] 010e 65536 ram14
[ 4.600941] (driver?)
[ 4.607171] 010f 65536 ram15
[ 4.607179] (driver?)
[ 4.613388] b300 31178752 mmcblk0
[ 4.613399] driver: mmcblk
[ 4.620260] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[ 4.628717] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2) ]---
2,032件の閲覧回数
Harvey021
From this log, like the one "[4.497948] VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -6" seems to be problem related partition.  Also recommend to check the configuration of bootargs in uboot.
Harvey
2,028件の閲覧回数
duyhai
This is the uboot env log, can you check it for me?
=> printenv
baudrate=115200
board_name=EVK
board_rev=14X14
boot_fdt=try
bootcmd=run findfdt;run findtee;mmc dev ${mmcdev};mmc dev ${mmcdev}; if mmc resc an; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi
bootcmd_mfg=run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes ; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else bootz ${loadaddr} ${in itrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot 0; fi;
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
console=ttymxc0
emmc_ack=1
emmc_dev=1
ethprime=eth1
fastboot_dev=mmc0
fdt_addr=0x83000000
fdt_file=undefined
fdt_high=0xffffffff
fdtcontroladdr=9de6c2d0
findfdt=if test $fdt_file = undefined; then if test $board_name = ULZ-EVK && tes t $board_rev = 14X14; then setenv fdt_file imx6ulz-14x14-evk.dtb; fi; if test $b oard_name = EVK && test $board_rev = 9X9; then setenv fdt_file imx6ull-9x9-evk.d tb; fi; if test $board_name = EVK && test $board_rev = 14X14; then setenv fdt_fi le imx6ull-14x14-evk.dtb; fi; if test $fdt_file = undefined; then echo WARNING: Could not determine dtb to use; fi; fi;
findtee=if test $tee_file = undefined; then if test $board_name = ULZ-EVK && tes t $board_rev = 14X14; then setenv tee_file uTee-6ulzevk; fi; if test $board_name = EVK && test $board_rev = 9X9; then setenv tee_file uTee-6ullevk; fi; if test $board_name = EVK && test $board_rev = 14X14; then setenv tee_file uTee-6ullevk; fi; if test $tee_file = undefined; then echo WARNING: Could not determine tee t o use; fi; fi;
image=zImage
initrd_addr=0x86800000
initrd_high=0xffffffff
ip_dyn=yes
kboot=bootz
loadaddr=0x80800000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadtee=fatload mmc ${mmcdev}:${mmcpart} ${tee_addr} ${tee_file}
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc clk_ ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot}
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${tee} = yes; then run l oadfdt; run loadtee; bootm ${tee_addr} - ${fdt_addr}; else if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then bootz ${loadaddr} - ${ fdt_addr}; else if test ${boot_fdt} = try; then bootz; else echo WARN: Cannot lo ad the DT; fi; fi; else bootz; fi; fi;
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} root=/dev/nfs ip=dhcp nfs root=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; ${usb_net_cmd}; run netargs; if test ${ip_dyn } = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; ${get_cmd} ${im age}; if test ${tee} = yes; then ${get_cmd} ${tee_addr} ${tee_file}; ${get_cmd} ${fdt_addr} ${fdt_file}; bootm ${tee_addr} - ${fdt_addr}; else if test ${boot_fd t} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then bootz ${loadaddr} - ${fdt_addr}; else if test ${boot_fdt} = try; then bootz ; else echo WARN: Cannot load the DT; fi; fi; else bootz; fi; fi;
script=boot.scr
sd_dev=1
serial#=614ecc90130ac1d7
splashimage=0x8c000000
tee=yes
tee_addr=0x84000000
tee_file=undefined
Environment size: 3338/8188 bytes
