We have NTSC video decoder giving BT656 input, we have verified the decoder is outputting correct,
Following IMX6UL TRM,
i.mx6ul CSI receive interlace ccir656 video issue and iMX7D : NTSC Video Capture
both doesn't answer the conclusion how
We tried as per the https://community.nxp.com/thread/473846 we even used the patch which was supplied by NXP, however their input was PAL, not NTSC.
Question we have
Is there any programming guide we can follow?
Answer from dh29 about this forum, we tried, then we get some output but its garbled.
Thank you in advance,
Hi weidong.sun,
We really appreciate your response, but we want answer on below.
Question we have
It would be really helpful if we have some example, with NTSC and PAL both BT656 input, taken as example and walk through the desired configuration with de-interlacer enabled.
-Rick
Hi richman,
Below is reply form i.MX Expert team:
ou can reference to followed patch, the CSI module and driver are same for iMX6ULL and IMX6UL, and PAL is more easy than NTSC to support: https://community.nxp.com/docs/DOC-330092
Document on the link is what I had sent to you before. this is our internal link, probably you couldn't access it. so I had to copy it and send to you.
After you patch it to your kernel, you can run images, then you will see all configurations for BT.656.
Have a nice day!
weidong sun
Hello weidong.sun
Please provide me access to this document, we are having lots of delay due to this lack of information and our production is delayed due to this.
Please provide a way to move forward,
-Rick
Hi rickman,
I see that you are using an i.MX6, which has an IPU, where I am using an i.MX7 without an IPU. As such the Linux framework used to process the CSI-MIPI is completely different.
I've finally got the i.MX7 working for both PAL and NTSC using the ADV7280 in PROGRESSIVE mode. See my post https://community.nxp.com/thread/480516 which I have just updated with how I got NTSC finally working. Unfortunately I don't think this will help your problem!
Hi dh29
No i am using IMX6ULL, and I followed your recent NTSC update hardcodinig the NTSC resolution instead of 480, and now I see some problem, but mostly due to my wrong configuration.
I think you and I are both in same page and same domain, yours is IMX7D and our platform is IMX6UL.
-Rick
Hi Rick,
Ah, I didn't realize that the i.MX6ULL also doesn't have an IPU. I'm afraid I only have experience of the i.MX7.
For the i.MX7 I used the Linux 'sub-device' framework i.e. /drivers/media/platform/mxc/subdev. I had to write a driver for the ADV7280, which I based on 'ov5647_mipi.c' and 'ov5640_mipi.c'. I also patched file 'mx6s_capture.c':
I then also ignored the i.MX V4L2 test applications.[I couldn't get them to work properly, and as I'm not building using YOCTO (I'm using BuildRoot) I kept having to jump back to a YOCTO build-system to re-compile the test-apps.] Instead I used gstreamer-1.0 for testing. The following was used to capture 3 frames to a file:
gst-launch-1.0 v4l2src device=/dev/video1 num-buffers=3 ! 'video/x-raw,format=(string)UYVY,width=(int)720,height=(int)507' ! filesink location=./tmp1
One of the problems I found of getting support on this forum regarding Video-Capture is that you can get 'answers' that are very specific to a particular Linux build / i.MX / capture-Device, which can be very misleading for your own platform. [I include my own answers here!] Hopefully something might help trigger a solution for you.
HI Rick,
Just to correct my statement:
- I had to add a definition for YUYV-16 (format used by the ADV7280) in 'struct mx6s_fmt'
I should have said that I added a definition for UYVY8_2X8 in struct mx6s_fmt as part of module mxc_mipi_csi.c:
static const struct csis_pix_format mipi_csis_formats[] = {
.code = MEDIA_BUS_FMT_YUYV8_2X8,
.fmt_reg = MIPI_CSIS_ISPCFG_FMT_YCBCR422_8BIT,
.data_alignment = 16,
.code = MEDIA_BUS_FMT_VYUY8_2X8,
.code = MEDIA_BUS_FMT_UYVY8_2X8,
.code = MEDIA_BUS_FMT_SBGGR8_1X8,
.fmt_reg = MIPI_CSIS_ISPCFG_FMT_RAW8,
.data_alignment = 8,
Hello rickman,
See below, please!
If you don't have files in attachments, you can submit a case to me via our salesforce system, I will send them to you by email!
You can follow below steps to submit your case:
1. open the link
https://www.nxp.com/support/support:SUPPORTHOME
2.In the middle of web page, under "Support Requests",Press "Go to Tickets"。
3.Log in;or register a new account,log in personal emal to validate information。
4.Log in web via account,Press "Add a folder"
5.after success, Add a new case? to submit a new question
weidong sun
