IMX6UL how to read or write from secure non-volatile storage (SNVS)
wayneshih
I am currently using YOCTO sumo linux kernel L4.14.98-2.3.1 with imx6ul.
In my application, we need to store our secure data (e.g key) inside secure non-volatile storage (SNVS) region. I don't know how to read/write the SNVS from either linux kernel space or user space.
Is there any example of how to read/write SNVS region?
haichao
Hi @wayneshih
Have you solved your problem? I have the same needs, I also need to store my secure data  inside secure non-volatile storage (SNVS) region,Can you share your experience
charlessteaderm
Hello @haichao and @wayneshih,
Were you able to make any progress with this? None of the answers that I see seem to apply to storing some arbitrary data (security keys) in a secure area.
Charlie
Hi wayneshih
for secure ram / secure storage examples one can refer to
AN12554 Demo Application to Generate Red/Black Blobs Using CAAM and Encrypt/Decrypt Data
https://www.nxp.com/docs/en/application-note/AN12554.pdf
https://source.codeaurora.org/external/imxsupport/imx_sec_apps/tree/demo-caam-blobs/README.txt
wayneshih
Thank for your quick reply igor.
The solutions you provide doesn't mention the secure non-volatile storage in imx6ul.
Is it because there is no easy way to access this region or this region is not design for storage security data?
