IMX6Solo, how the Qt hellogl2 example works
ソリューションへジャンプ
73,145件の閲覧回数
SeungGeun_Lee
I would like to know how the Qt hellogl2 example works.
0. Enviroment
    - i.MX6 Solo custom board + Yocto + "X11" + Qt5
1. Kernel
    - imx_4.19.35_1.1.0
    https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm?h=rel_imx_4.19.35_1.1.0
2. default dts
    - imx6dl-sabresd.dts
    https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm/boot/dts/imx6dl-sabresd.dts?h=rel...
3. default config
    - imx_v7_defconfig
    https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm/configs/imx_v7_defconfig?h=rel_im...
3. my kernel dts (attached file)
4. my kernel config (attached file)
5. dmesg (attached file)
6. qt hellogl2 log (attached file)
7. Xorg log (attached file)
As shown in the picture below, the opengl area only shows a black screen
ラベル(3)
73,134件の閲覧回数
SeungGeun_Lee
i resolved issue
1. My xorg.conf created after yocto build is as follows.
root@imx6solosabresd-custom:~# cat /etc/X11/xorg.conf
Section "Device"
    Identifier "i.MX Accelerated Framebuffer Device"
    Driver "vivante"
    Option "fbdev" "/dev/fb0"
    Option "vivante_fbdev" "/dev/fb0"
    Option "HWcursor" "false"
EndSection
Section "ServerFlags"
    Option "BlankTime" "0"
    Option "StandbyTime" "0"
    Option "SuspendTime" "0"
    Option "OffTime" "0"
EndSection
2. When I applied xorg.conf as the contents of the i.MX Reference Manual, opengl worked.
https://www.nxp.com/docs/en/reference-manual/i.MX_Reference_Manual_Linux.pdf
5.3.2.5 xorg.conf for i.MX
Section "ServerLayout"
    Identifier "Default Layout"
    Screen "Default Screen"
EndSection
Section "Module"
    Load "dbe"
    Load "extmod"
    Load "freetype"
    Load "glx"
    Load "dri"
EndSection
Section "InputDevice"
    Identifier "Generic Keyboard"
    Driver "kbd"
    Option "XkbLayout" "us"
    Option "XkbModel" "pc105"
    Option "XkbRules" "xorg"
EndSection
    Identifier "Configured Mouse"
    Driver "mouse"
    Option "CorePointer"
EndSection
Section "Device"
    Identifier "Your Accelerated Framebuffer Device"
    Driver "vivante"
EndSection
Section "Monitor"
    Identifier "Configured Monitor"
EndSection
Section "Screen"
    Identifier "Default Screen"
    Monitor "Configured Monitor"
    Device "Your Accelerated Framebuffer Device"
    DefaultDepth 24
EndSection
Section "DRI"
    Mode 0666
EndSection
3.
2 返答(返信)
73,135件の閲覧回数
SeungGeun_Lee
i resolved issue
Section "Device"
    Driver "vivante"
EndSection
EndSection
EndSection
Section "Module"
    Load "dbe"
    Load "extmod"
    Load "freetype"
    Load "glx"
    Load "dri"
EndSection
    Driver "kbd"
EndSection
    Driver "mouse"
EndSection
Section "Device"
    Driver "vivante"
EndSection
Section "Monitor"
EndSection
Section "Screen"
    DefaultDepth 24
EndSection
Section "DRI"
    Mode 0666
EndSection
3.
73,127件の閲覧回数
Bio_TICFSL
Hello SeungGeun,
What i can see the code it working, it just show you the QT while you can variance the alpha blending
