IMX6SX openOCD configuration file
6,640 次查看
tcmichals
I'm trying to create a new configuration file for the IMX6SX, in mode =0, the chain is |SJC | SDMA| DAP_A9 |DAP_M4
How/where do you get the ID's for each block?  i.e SDMA? DAP_A9? DAP_M4?
# CoreSight Debug Access Port
if { [info exists DAP_TAPID_A9] } {
   set _DAP_TAPID_A9 $DAP_TAPID_A9
} else {
   set _DAP_TAPID_A9 0x1ba00477  <-- How is the number
if { [info exists DAP_TAPID_M4] } {
   set _DAP_TAPID_M4 $DAP_TAPID_M4
} else {
   set _DAP_TAPID_M4 0x1ba00477 <-- Where/How is this ID created?
jtag newtap $_CHIPNAME DAP -irlen 4 -ircapture 0x2 -irmask 0xf \
        -expected-id $_DAP_TAPID_A9
# SDMA / no IDCODE
jtag newtap $_CHIPNAME SDMA -irlen 4 -ircapture 0x0 -irmask 0xf
# SJC
if { [info exists SJC_TAPID] } {
   set _SJC_TAPID SJC_TAPID
} else {
   set _SJC_TAPID 0x0190d01d <-- How is this number created
5,179 次查看
tcmichals
Here is a working imx6sx.cfg.  The issue was in the reset commands.  Able to stop, single step, load
transport select jtag
# Slow speed to be sure it will work
adapter_khz 1000
if { [info exists CHIPNAME] } {
   set  _CHIPNAME $CHIPNAME
} else {
   set  _CHIPNAME imx6sx
if { [info exists DAP_TAPID] } {
        set _DAP_TAPID $DAP_TAPID
} else {
        set _DAP_TAPID 0x4ba00477
jtag newtap $_CHIPNAME dapM4 -irlen 4 -ircapture 0x01 -irmask 0x0f \
jtag newtap $_CHIPNAME dapA9 -irlen 4 -ircapture 0x01 -irmask 0x0f \
jtag newtap $_CHIPNAME sdma -irlen 5 -ircapture 0x0 -irmask 0x0f \
        -expected-id 0x1
jtag newtap $_CHIPNAME sjc -irlen 4 -ircapture 0x0 -irmask 0x0f \
        -expected-id 0x0891C01D
target create imx6sx.dapM4 cortex_m  -chain-position imx6sx.dapM4
imx6sx.dapM4 configure -event "reset-assert" {
  echo "Reseting ...."
  #cortex_a dbginit
imx6sx.dapM4 configure -event reset-init { m4_init }
proc m4_init { } {
  echo "Reset-init..."
  ; # halt the CPU
  halt
  dap apsel 0
  cortex_m reset_config vectreset
9 回复数
5,180 次查看
tcmichals
adapter_khz 1000
} else {
} else {
        -expected-id 0x1
  #cortex_a dbginit
proc m4_init { } {
  ; # halt the CPU
  halt
  dap apsel 0
5,179 次查看
fatalfeel
5,179 次查看
tcmichals
Jesse,
Thank you your help; the configuration script I'm trying to use is for a imx6sx A9/M4, the cfg files you sent are for imx6d, and imx6q.
5,179 次查看
fatalfeel
look into the cfg file and search ur imx6sx .h file compare of them
do ur own cfg
5,179 次查看
Yuri
  Using “attribute IDCODE_REGISTER of MX6SLX” from its BSDL file.
SJC_TAPID 0x0891c01d
  As for CoreSight Debug Access Ports (one for A9, and one for M4)
You may try DAP_TAPID 0x4ba00477 or just to skip them as SDMA.
Yuri
5,179 次查看
tcmichals
I was looking at the BSDL file and trying to figure out how you got the values:
Yes there is  DAP for each core,  so each one will have a different ID? one for the M4 the other for the A9?
Thank you for your help.
5,179 次查看
tcmichals
OK, I finally have OpenOCD connecting; but still need more information.
OK there are 4 taps:
SJC_0              -  0x0891c01d
SDMA_0          -
ARMCS-DP_0 -
Cortex-A9_0
ARMCS-DP_1
Cortex-M4_0
Here is a start for configuration file for opencod:
# Freescale i.MX6SX series single/dual/quad core processor
} else {
# CoreSight Debug Access Port A9..
} else {
jtag newtap $_CHIPNAME dap -irlen 4 -ircapture 0x01 -irmask 0x0f \
# SDMA / no IDCODE
jtag newtap $_CHIPNAME sdma -irlen 4 -ircapture 0x00 -irmask 0x0f
# System JTAG Controller
        set _SJC_TAPID $SJC_TAPID
} else {
        set _SJC_TAPID 0x0891c01d
#SDMA
set _SJC_TAPID2 0x2191c01d
#DAP for ARM Cortex A9
set _SJC_TAPID3 0x2191e01d
#ARM Cortex A9
set _SJC_TAPID4 0x1191c01d
#DAP for ARM M4
#ARM Cortex M4
#below needs to change to only use the M4 not A9
jtag newtap $_CHIPNAME sjc -irlen 5 -ircapture 0x01 -irmask 0x1f \
        -expected-id $_SJC_TAPID -expected-id $_SJC_TAPID2 \
        -expected-id $_SJC_TAPID3 -expected-id $_SJC_TAPID4
# GDB target: Cortex-A9, using DAP, configuring only one core
# Base addresses of cores:
# ARM Cortex -A9  -  0x82150000
# core 0  -  0x82152000
set _TARGETNAME $_CHIPNAME.cpu.0
#need to change this for M4..
target create $_TARGETNAME cortex_a -chain-position $_CHIPNAME.dap \
        -coreid 0 -dbgbase 0x82150000
# some TCK cycles are required to activate the DEBUG power domain
jtag configure $_CHIPNAME.sjc -event post-reset "runtest 100"
proc imx6_dbginit {target} {
        # General Cortex A8/A9 debug initialisation
        cortex_a dbginit
adapter_khz 1000
$_TARGETNAME configure -event reset-start { adapter_khz 1000 }
        cortex_a dbginit
adapter_khz 1000
$_TARGETNAME configure -event reset-assert-post "imx6_dbginit $_TARGETNAME"
$_TARGETNAME configure -event gdb-attach { halt }
5,179 次查看
tcmichals
I've done an auto scan... here is was devices were found
adapter speed: 1000 kHz
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
RCLK - adaptive
Info : RCLK (adaptive clock speed) not supported - fallback to 8 kHz
Warn : There are no enabled taps.  AUTO PROBING MIGHT NOT WORK!!
Info : JTAG tap: auto0.tap tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : JTAG tap: auto1.tap tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : TAP auto2.tap does not have IDCODE
Info : JTAG tap: auto3.tap tap/device found: 0x0891c01d (mfg: 0x00e, part: 0x891c, ver: 0x0)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 4 -expected-id 0x4ba00477"
Warn : AUTO auto1.tap - use "jtag newtap auto1 tap -irlen 8 -expected-id 0x4ba00477"
Warn : AUTO auto2.tap - use "jtag newtap auto2 tap -irlen 5 -expected-id 0x00000000"
Warn : AUTO auto3.tap - use "jtag newtap auto3 tap -irlen 2 -expected-id 0x0891c01d"
Error: auto3.tap: IR capture error; saw 0x0003 not 0x0001
Warn : Bypassing JTAG setup events due to errors
Warn : gdb services need one or more targets defined
5,179 次查看
tcmichals
Shown below is the configuration for openOCD (imx6sx.cfg)
Need to enable the clock and start the M4; when the command "monitor reset init " it locks up the A9; some times it does not;  is there some additional registers to setup?
starting openocd:
sudo  ./src/openocd -f interface/ftdi/jtagkey.cfg -f ./tcl/target/imx6sx.cfg
imx6sx.cfg:
adapter_khz 1000
} else {
} else {
        -expected-id 0x1
