IMX6S OCRAM access
IMX6S OCRAM access
5,375 次查看
fabricealcindor
In the thread of VPU driver implementation I need to use internal RAM. On the linux driver OCRAM is used for this purpose.
What are the pre-requisite to use this memory. I actually fail trying to access this memory. I tried some clocks setup without any success.
Fabrice
9 回复数
4,882 次查看
AnsonHuang
Hi, Fabrice
     Can you tell me which memory space you tried to access, and how you accessed it?
4,882 次查看
fabricealcindor
I try to access the internal RAM of  IMX6 solo so called  OCRAM at address 0x00900000 by simple C instruction like
*(0x00900000)=0.
4,882 次查看
AnsonHuang
Have you considered the MMU enabled case, where did you put this code? In kernel? If it is in kernel, then the physical address can NOT be accessed directly.
4,882 次查看
fabricealcindor
I tried in a linux user-space application and a vxworks task. in last case MMU is not enabled.
4,882 次查看
AnsonHuang
Then I can NOT understand why, the only possibility is that MMU is enabled, can you try it in uboot with md command?
4,882 次查看
fabricealcindor
indeed I can access to this memory during uboot. So MMU might be enabled. I'll check that.
4,882 次查看
YixingKong
Senior Contributor IV
Fabrice
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
4,882 次查看
YixingKong
Fabrice
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
4,882 次查看
YixingKong
Fabrice
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
