Hi Siva
for using mfg tool with custom board it is necessary to rebuild firmware
(files in mfg tool /firmware folder), replace with new ones using new memory calibration
settings found from ddr test (put them in uboot/../mx6sabresd/mx6q_4x_mt41j128.cfg),
please use sect.6.2 Manufacturing Tool, MFGTool attached Yocto Guide.
Use mfg tool corresponding to used kernel version, found on
i.MX Software|NXP
