IMX6第一次上电启动不了,我们用的是IMX6Q,在所有电断开一段时间后,有两块板子出现第一次启动不了!串口也没打印信息!后来测试发现RTC晶振这里有影响,我只要示波器点击晶振的IN或者飞线出来就可以正常启动,但是测试晶振也是震荡没问题的,为啥这里受影响?我将晶振的IN给短接到地也可以启动,更改晶振的匹配电容没用!不知道具体哪里原因引起启动异常!异常时候我再立刻上电就可以起来或者对CPU复位也可以起来,放置久就不行!我从量时序和BOOT配置没发现有明显异常?帮忙给下分析思路,谢谢!
Hi Tommy,
You can try like below:
1. Populated 10M resistor between IN and OUT of CPU Cystal PIN.
or
2. Remove 32.768K crystal , 2 capacitors and 10M resistor.
Try it please!
TIC Weidong
Thanks your relay!
1、Two pieces of bad,one pcs is OK we Populated 2M resistor between IN and OUT of CPU Cystal PIN;The other one goes your way,Populated 10M resistor between IN and OUT of CPU Cystal PIN.it still can't start first!
2、I remove RTC CLK,it's OK!
Can you tell me the really reason,or What experiments we need to do?To avoid this problem in the future!
Best Regards
