[IMX6D]How to change the parameters of LVDS signal
dengw2
Dear Commuity,
We are developing a cluster based on IMX6D. TFT LCD with open ldi interface has been used.
After test the eye diagram of display lvds signal, some parameters are NG:
Clock high time (TLVCH)
Clock low time (TLVCL)
strobe width (TSW)
Please help to check is it possible to change the parameters of LVDS signal by software?
Thanks.
Labels (2)
Hi Wu
for i.MX6DQ I am afraid it is not possible to change the parameters of LVDS signal in
software. So it is necessary to pay attention to hardware: board layout, connectors, cables
impedance matching. In particular, from sect.4.8.3 LVDS I/O Output Buffer Impedance, sect.4.12.11 LVDS Display Bridge (LDB) Module Parameters  i.MX 6Dual/6Quad Applications Processors for Consumer Products - Data Sheet
The LVDS interface complies with TIA/EIA 644-A standard. For more details, see TIA/EIA STANDARD
644-A, “Electrical Characteristics of Low Voltage Differential Signaling (LVDS) Interface Circuits.”
dengw2
Dear igor,
Thanks for your help. we will check from h/w side.
Thanks.
Hi Wu
