Hi All,
i'm working with a dvb-t dongle, aiming to watch tv on a MX6Q.
i'm using ltib filesystem with kernel 3.0.35
this is my not-working pipeline:
gst-launch-0.10 dvbbasebin bandwidth=8 code-rate-lp=AUTO code-rate-hp=AUTO guard=AUTO hierarchy=AUTO modulation=AUTO trans-mode=AUTO inversion=AUTO frequency=$f program-numbers=$pn ! mpegtsdemux name=demux ! queue max-size-buffers=0 max-size-time=0 ! mfw_mpeg2decoder ! mfw_v4lsink axis-top=0 axis-left=0 disp-width=$WIDTH disp-height=$HEIGHT axis-top=$Y setpara=1
! consider that substituting mfw_mpeg2decoder with ffdec_mpeg2video there is not segfault (but video has frames dropped) !
please give me an hint to solve this problem!
this is my console output:
root@freescale /$ export GST_DEBUG=mfw*:5
MPEG2D_ARM11_02.02.00 build on Apr 19 2011 19:06:38.
MFW_GST_MPEG2_DECODER_PLUGIN 3.0.5 build on Jan 31 2013 08:30:42.
0:00:01.057304156 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:262:mfw_gst_get_first_odev: Get first device:/dev/video16, capabilities 0x4000002
0:00:01.057596823 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[RGBP]RGB565
0:00:01.057674822 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[BGR3]BGR24
0:00:01.057745822 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[RGB3]RGB24
0:00:01.057812822 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[RGB4]RGB32
0:00:01.057879489 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[BGR4]BGR32
0:00:01.057944156 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[NV12]NV12
0:00:01.058009156 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[UYVY]UYVY
0:00:01.058073156 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[YUYV]YUYV
0:00:01.058138489 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[422P]YUV422 planar
0:00:01.058202489 2606 0x17050 WARN mfw_v4lsink mfw_gst_v4lsink.c:303:mfw_gst_v4l2sink_query_support_formats: unrecognized format:[Y444]YUV444
0:00:01.058268822 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[YU12]YUV420
0:00:01.058333489 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[YV12]YVU420
0:00:01.058397489 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[TNVP]TILED NV12P
0:00:01.058461489 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[TNVF]TILED NV12F
0:00:01.058525155 2606 0x17050 INFO mfw_v4lsink mfw_gst_v4lsink.c:300:mfw_gst_v4l2sink_query_support_formats: supported format:[444P]YUV444 planar
MFW_GST_V4LSINK_PLUGIN 3.0.5 build on Jan 31 2013 08:29:57.
0:00:01.060863154 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:782:mfw_gst_v4lsink_set_property: axis_top = 0
0:00:01.060979487 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:786:mfw_gst_v4lsink_set_property: axis_left = 0
0:00:01.061081154 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:774:mfw_gst_v4lsink_set_property: width = 800
0:00:01.061181487 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:778:mfw_gst_v4lsink_set_property: height = 450
0:00:01.061282154 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:782:mfw_gst_v4lsink_set_property: axis_top = 85
Setting pipeline to PAUSED ...
0:00:01.062855153 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:1468:mfw_gst_v4lsink_change_state:
>>V4LSINK: State: 10
0:00:01.705054828 2606 0x17050 DEBUG mfw_v4lsink mfw_gst_v4lsink.c:1468:mfw_gst_v4lsink_change_state:
>>V4LSINK: State: 19
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
** (gst-launch-0.10:2606): CRITICAL **: Could not convert string: Conversion from character set 'iso8859-9' to 'utf-8' is not supported
(gst-launch-0.10:2606): GStreamer-WARNING **: Trying to set string on structure field 'extended-text', but string is not valid UTF-8. Please file a bug.
** (gst-launch-0.10:2606): CRITICAL **: Could not convert string: Conversion from character set 'iso6937' to 'utf-8' is not supported
0:00:08.375314161 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1007:mfw_gst_mpeg2dec_sink_event: handling newsegment event
0:00:08.375504494 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1019:mfw_gst_mpeg2dec_sink_event: receiving new seg
0:00:08.375590828 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1020:mfw_gst_mpeg2dec_sink_event: start = 20:22:25.317944444
0:00:08.375658161 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1021:mfw_gst_mpeg2dec_sink_event: stop = 99:99:99.999999999
0:00:08.375721828 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1024:mfw_gst_mpeg2dec_sink_event: position in mpeg2dec =0:00:00.000000000
0:00:08.375952161 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1116:mfw_gst_mpeg2dec_set_caps: in mfw_gst_mpeg2dec_set_caps function
0:00:08.376037828 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:1127:mfw_gst_mpeg2dec_set_caps: Frame Rate = nan
0:00:08.376215828 2606 0x106348 DEBUG mfw_mpeg2decoder mfw_gst_mpeg2dec.c:681:mfw_gst_mpeg2dec_chain:
Coming for the first time to do the decoder initialization
Caught SIGSEGV accessing address 0x14
Spinning. Please run 'gdb gst-launch 2606' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
root@freescale /$
