IMX6 IPU waveform set
mjrudy
Can anyone tell me what the waveform set is actually doing?  I looked at the timing generation in the reference manual but don't fully understand what this does.
When I use set 2 which was the default setting of the IMX6 SDK I believe, I get a very slow strange ghosting affecting.  It starts in the corners of the display and moves slowly into the center.
When I use a set of 3 it seems better but I'm just not sure why.
I'm also using an RGB to MIPI converter but this was originally used with an IMX53 with not issues.
