IMX6 GPIO CONTROL PROBLEM
1,752件の閲覧回数
sebastianpszczo
I have problem with GPIO pin on Board sabre SDP. When I export by SYSF pin EIM_DA0 I can't change value of this pin but when I export pin EIM_D18 I can change value without problem(I checked on osciloscope). I didn't see in device tree any configuration of that both pin but one work(EIM_D18)  and  EIM_DA0 doesn't. Do I need export pin to DeviceTree when I want use it as GPIO in SYSFS? Thank you
タグ(1)
1,570件の閲覧回数
weidong_sun
Hello bb,
    Yes, you need to add it to device tree and multiplex it as GPIO.
Weidong
