IMX6 CSI Test Mode
IMX6 CSI Test Mode
joanvicient
Hi all,
I am trying to enable the IPU CSI TEST_GEN_MODE. I am following the indications of the i.IMX BSP Porting Guide (Section "Configuring the CSI unit in test mode") but without succes, as I am not able to receive any image. In the document talks about a sample driver named ipuv3_csi0_chess.c. Is this code (or any equivalent) available?
Tags (3)
Hi joan
one can try attached patch.
Hi joan
joanvicient
Thanks. The code worked!
