How to use i.MX6ULL ADC hardwear trigger mode in Reference Manual?
Does hardware trigger mode of ADC is only for touch screen?
If not, Please advice how to use hardwear trigger mode for another usage?
Sugiyama
Hi Sugiyama
hardware triggering is not supported on the ADC i.MX6UL and 6ULL.
Hi, Igor,
Thank you for reply.
Do you mean hardwear trigger is only for touch screen?
There is a description of touch screen in reference manual Chapter 54 Touch Screen Controller (TSC).
Sugiyama
Hi Sugiyama
not touch screen,
Confirmed by application team.
Hi ,Igor,
Thank you.
However, i.MX6UL/ULL support touch screen function with ADC. Is it right?
Sugiyama
Hi Sugiyama
answer was provided for ADC hardware trigger.
Touch screen function with ADC is supported.
Touch screen function with ADC hardware trigger is not supported.
From sect.51.2.2.5 ADC-TSC co-working i.MX6UL Reference Manual :
"TSC starts ADC :
TSC sends two signals: trigger and hardware trigger select signal: HWTS[4:0]."
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
