IMX53: aplay command not found
3,173 次查看
swaraj
If i try to use aplay or gplay , it says "-sh: aplay: not found". What might be the reason for it.?
2,215 次查看
swaraj
Daiane Angolini said:
You should enable alsa packages on LTIB packages.
Are you using ltib to generate rootfs?
Hi Daiane Angolini, Thanks for your reply. I generated rootfs using ltib and i created spdif as a module. I uploaded config file which was used for building rootfs. What are the packages required for aplay.
2,215 次查看
daiane_angolini
