IMX51_bbg
已解决
IMX51_bbg
跳至解决方案
4,169 次查看
wagnergoncalves
Hello friends I have a media center with the RoadRover processor imx51_bbg
I'm trying to make some changes in the firmware of this device, but I can not make the unpack and repack the files system.img and uboot, someone from the forum could indicate what programs I could use to handling the same
I thank you.
标签 (2)
1 解答
2,660 次查看
4guin4g4
Depending on what you want to modify, you can try building again the kernel and u-boot by going to
.../myandroid/kernel_imx
and executing
make menuconfig
在原帖中查看解决方案
1 回复
2,661 次查看
4guin4g4
and executing
make menuconfig
