IMX1176 bootloader
IMX1176 bootloader
882 次查看
tbayram
Im working on IMX1176 EVK. I want to write a bootloader. But I have a problem on this subject. I wrote a bootloader and application code. when the code is in debug bootloader code jump the application but after reset application code is not work. How can I solve this problem? Could you help me?
861 次查看
xjy198903
What are your hardware connections like? If USB is used, you need to turn off the USB clock before jumping
