IMX RT1170 EVKB - Access policy behavior issue when trying to block an eDMA transfer using XRDC
577 次查看
mneroda
Dear NXP Support Team,
I am making eDMA memory to memory transfer that I want to allow or not from writing in a specific memory address by using the XRDC2.
The issue is that I can't manage to make the access policy work right.
Here is how I assign a Domain ID to the eDMA Bus Master :
xrdc2_master_domain_assignment_t assignment;
XRDC2_GetDefaultMasterDomainAssignment(&assignment);
/* Defining privileges to the EDMA */
assignment.lock = false;
assignment.privilegeAttr = kXRDC2_ForcePrivilege;
assignment.secureAttr = kXRDC2_ForceNonSecure;
assignment.domainId = 3;
XRDC2_SetMasterDomainAssignment(DEMO_XRDC2, kXRDC2_Master_M7_EDMA, 0, &assignment);
XRDC2_SetMasterDomainAssignment(DEMO_XRDC2, kXRDC2_Master_M4_EDMA, 0, &assignment);
Here is how I assign the access rights to the memory that I want to manage with the XRDC :
xrdc2_mem_access_config_t memAccessConfig;
XRDC2_GetMemAccessDefaultConfig(&memAccessConfig);
memAccessConfig.startAddr = DEMO_XRDC2_MEM_START_ADDR;
memAccessConfig.endAddr = DEMO_XRDC2_MEM_END_ADDR;
memAccessConfig.policy[3] = kXRDC2_AccessPolicyAlt6;
But this configuration blocks the EDMA transfer from happening. Normally the transfer should happen as eDMA is assigned to the Domain ID 3 that has the NonSecurePriv attributes and as I am using the kXRDC2_AccessPolicyAlt6 policy (which gives NonSecurePriv transfers read and write rights) over the memory I want to manage with the XRDC2.
I only manage to block or allow that eDMA transfer when assigning the eDMA to the Domain ID 0 (which is the default one) and when I use the kXRDC2_AccessPolicyAll and kXRDC2_AccessPolicyNone access policy. I don't understand actually why the other access policies does not work as intended when using the Domain ID 0. For example when using kXRDC2_AccessPolicyAlt3 the transfer is happening but it should not.
I feel like I am not not assigning the eDMA Bus Master to the Domains correctly. That is why the behaviors of the eDMA transfers are not working like I want.
In case you need more details or bites of my code feel free to reach out ! Thanks !
449 次查看
Kan_Li
Hi @mneroda ,
The match for M7 DMA is MATCH[14:0]= {CHANNEL_ID[4:0],HMASTER[3:0],XID[5:0]}  , you may mask the XID part, and set up CHANNEL_ID and HMASTER according to your application. Please kindly refer to the following for details.
CHANNEL_ID: channel id from EDMA, indicates DMA channel index
• HMASTER: Master id from EDMA, indicates the master id of master that
programmed the DMA channel that is active
Kan
480 次查看
Kan_Li
 Hi @mneroda ,
Did you also set up assignment as below? Please kindly clarify.
assignment.mask  = 0xFFFFFFFFUL;
assignment.match = 0UL;
Kan
457 次查看
mneroda
Hi @Kan_Li ,
Thanks a lot for your answer.
Yes I've set up the assignment as you did and I managed to block the eDMA transfer with the XRDC as I wanted. I did another post that shows how I am making that assignment : https://community.nxp.com/t5/i-MX-RT-Crossover-MCUs/IMX-RT1170-EVKB-How-to-configure-XRDC2-domain-as....
However, I would like to know if it is possible to fine tune the MASK and MATCH field because by setting the fields as you show it seems like a hit is generated for all the eDMA transfers (I only want to block the DMA0 transfers). The previous link I have shared is a post about this topic.
Mickaël
450 次查看
Kan_Li
Hi @mneroda ,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2139974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMX%20RT1170%20EVKB%20-%20%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20XRDC%20%E9%98%BB%E6%AD%A2%20eDMA%20%E4%BC%A0%E8%BE%93%E6%97%B6%E7%9A%84%E8%AE%BF%E9%97%AE%E7%AD%96%E7%95%A5%E8%A1%8C%E4%B8%BA%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%94%AF%E6%8C%81%E5%9B%A2%E9%98%9F%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20XRDC2%20%E8%BF%9B%E8%A1%8C%20eDMA%20%E5%AD%98%E5%82%A8%E5%99%A8%E5%88%B0%E5%AD%98%E5%82%A8%E5%99%A8%E7%9A%84%E4%BC%A0%E8%BE%93%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E5%85%81%E8%AE%B8%E6%88%96%E4%B8%8D%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AD%98%E5%82%A8%E5%99%A8%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E6%98%AF%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E8%AE%BF%E9%97%AE%E7%AD%96%E7%95%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%90%91%20eDMA%20%E6%80%BB%E7%BA%BF%E4%B8%BB%E7%AB%99%E5%88%86%E9%85%8D%E5%8A%9F%E8%83%BD%E5%9F%9F%20ID%20%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Exrdc2_master_domain_assignment_t%20%E5%88%86%E9%85%8D%EF%BC%9B%3C%2FP%3E%3CP%3EXRDC2_GetDefaultMasterDomainAssignment(%26amp%3Bassignment)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%AE%9A%E4%B9%89%20EDMA%20%E7%9A%84%E6%9D%83%E9%99%90%20*%2F%3CBR%20%2F%3Eassignment.lock%20%3D%20false%3B%3CBR%20%2F%3Eassignment.privilegeAttr%3D%20kXRDC2_ForcePrivilege%3B%3CBR%20%2F%3Eassignment.secureAttr%20%3D%20kXRDC2_ForceNonSecure%3B%3CBR%20%2F%3Eassignment.domainId%20%3D%203%EF%BC%9B%3C%2FP%3E%3CP%3EXRDC2_SetMasterDomainAssignment(DEMO_XRDC2%2C%20kXRDC2_Master_M7_EDMA%2C%200%2C%26amp%3Bassignment)%EF%BC%9B%3C%2FP%3E%3CP%3EXRDC2_SetMasterDomainAssignment(DEMO_XRDC2%2C%20kXRDC2_Master_M4_EDMA%2C%200%2C%26amp%3Bassignment)%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E5%A6%82%E4%BD%95%E4%B8%BA%E8%A6%81%E7%94%A8%20XRDC%20%E7%AE%A1%E7%90%86%E7%9A%84%E5%AD%98%E5%82%A8%E5%99%A8%E5%88%86%E9%85%8D%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%EF%BC%9A%3C%2FP%3E%3CP%3Exrdc2_mem_access_config_t%20memAccessConfig%EF%BC%9B%3C%2FP%3E%3CP%3EXRDC2_GetMemAccessDefaultConfig(%26amp%3BmemAccessConfig)%EF%BC%9B%3C%2FP%3E%3CP%3EmemAccessConfig.startAddr%20%3D%20DEMO_XRDC2_MEM_START_ADDR%3B%3CBR%20%2F%3EmemAccessConfig.endAddr%20%3D%20DEMO_XRDC2_MEM_END_ADDR%3B%3CBR%20%2F%3EmemAccessConfig.policy%5B3%5D.%3D%20kXRDC2_AccessPolicyAlt6%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BD%86%E8%BF%99%E7%A7%8D%E9%85%8D%E7%BD%AE%E4%BC%9A%E9%98%BB%E6%AD%A2%20EDMA%20%E4%BC%A0%E8%BE%93%E3%80%82%E9%80%9A%E5%B8%B8%EF%BC%8C%E4%BC%A0%E8%BE%93%E5%BA%94%E8%AF%A5%E5%9C%A8%20eDMA%20%E5%88%86%E9%85%8D%E7%BB%99%E5%85%B7%E6%9C%89%E9%9D%9E%20SecurePriv%20%E5%B1%9E%E6%80%A7%E7%9A%84%E5%8A%9F%E8%83%BD%E5%9F%9F%20ID%203%20%E6%97%B6%E8%BF%9B%E8%A1%8C%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%9C%A8%E6%88%91%E6%83%B3%E7%94%A8%20XRDC2%20%E7%AE%A1%E7%90%86%E7%9A%84%E5%86%85%E5%AD%98%E4%B8%8A%E4%BD%BF%E7%94%A8%20KxRDC2_AccessPolicyAlt6%20%E7%AD%96%E7%95%A5%EF%BC%88%E8%B5%8B%E4%BA%88%E9%9D%9E%20SecurePriv%20%E4%BC%A0%E8%BE%93%E7%9A%84%E8%AF%BB%E5%86%99%E6%9D%83%E9%99%90%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%B0%86%20eDMA%20%E5%88%86%E9%85%8D%E7%BB%99%E5%8A%9F%E8%83%BD%E5%9F%9F%20ID%200%EF%BC%88%E9%BB%98%E8%AE%A4%E5%8A%9F%E8%83%BD%E5%9F%9F%EF%BC%89%E4%BB%A5%E5%8F%8A%E4%BD%BF%E7%94%A8%20kxrdc2_accessPolicyAll%20%E5%92%8C%20kxrdc2_accessPolicyAll%20%E5%92%8C%20kxrdc2_accessPolicyNone%20%E8%AE%BF%E9%97%AE%E7%AD%96%E7%95%A5%E6%97%B6%EF%BC%8C%E6%89%8D%E8%83%BD%E8%AE%BE%E6%B3%95%E5%B1%8F%E8%94%BD%E6%88%96%E5%85%81%E8%AE%B8%20eDMA%20%E8%BD%AC%E7%A7%BB%E3%80%82%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%8A%9F%E8%83%BD%E5%9F%9F%20ID%200%20%E6%97%B6%E5%85%B6%E4%BB%96%E8%AE%BF%E9%97%AE%E7%AD%96%E7%95%A5%E6%97%A0%E6%B3%95%E6%8C%89%E9%A2%84%E6%9C%9F%E8%BF%90%E8%A1%8C%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BD%93%E4%BD%BF%E7%94%A8%20kxrdc2_accessPolicyAlt3%20%E6%97%B6%EF%BC%8C%E4%BC%A0%E8%BE%93%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%EF%BC%8C%E4%BD%86%E4%BA%8B%E5%AE%9E%E5%B9%B6%E9%9D%9E%E5%A6%82%E6%AD%A4%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%A7%89%E5%BE%97%E6%88%91%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E5%9C%B0%E5%B0%86%20eDMA%20%E6%80%BB%E7%BA%BF%E4%B8%BB%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%88%86%E9%85%8D%E7%BB%99%E5%8A%9F%E8%83%BD%E5%9F%9F%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%20eDMA%20%E4%BC%A0%E8%BE%93%E8%A1%8C%E4%B8%BA%E6%97%A0%E6%B3%95%E5%A6%82%E6%88%91%E6%89%80%E6%84%BF%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%E6%88%96%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E8%81%94%E7%B3%BB%E6%88%91%EF%BC%81%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2139974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%20RT1170%20EVKB%20-%20Access%20policy%20behavior%20issue%20when%20trying%20to%20block%20an%20eDMA%20transfer%20using%20XRDC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149099%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253043%22%20target%3D%22_blank%22%3E%40mneroda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an%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%20RT1170%20EVKB%20-%20Access%20policy%20behavior%20issue%20when%20trying%20to%20block%20an%20eDMA%20transfer%20using%20XRDC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E5%83%8F%E4%BD%A0%E4%B8%80%E6%A0%B7%E5%AE%89%E8%A3%85%E4%BA%86%E4%BB%BB%E5%8A%A1%EF%BC%8C%E6%88%91%E8%AE%BE%E6%B3%95%E6%8C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E6%84%8F%E6%84%BF%E5%B1%8F%E8%94%BD%E4%BA%86%20XRDC%20%E7%9A%84%20eDMA%20%E8%BD%AC%E8%B4%A6%E3%80%82%E6%88%91%E5%9C%A8%E5%8F%A6%E4%B8%80%E7%AF%87%E6%96%87%E7%AB%A0%E4%B8%AD%E4%BB%8B%E7%BB%8D%E4%BA%86%E6%88%91%E6%98%AF%E5%A6%82%E4%BD%95%E5%AE%8C%E6%88%90%E8%BF%99%E9%A1%B9%E4%BB%BB%E5%8A%A1%E7%9A%84%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FIMX-RT1170-EVKB-How-to-configure-XRDC2-domain-assignment-for-an%2Fm-p%2F2147528%23M34902%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FIMX-RT1170-EVKB-How-to-configure-XRDC2-domain-as....%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%AF%B9%20MASK%20%E5%92%8C%20MATCH%20%E5%AD%97%E6%AE%B5%E8%BF%9B%E8%A1%8C%E5%BE%AE%E8%B0%83%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%8C%89%E7%85%A7%E6%82%A8%E6%89%80%E6%98%BE%E7%A4%BA%E7%9A%84%E6%96%B9%E5%BC%8F%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%BA%9B%E5%AD%97%E6%AE%B5%EF%BC%8C%E4%BC%BC%E4%B9%8E%E6%89%80%E6%9C%89%20eDMA%20%E4%BC%A0%E8%BE%93%E9%83%BD%E4%BC%9A%E4%BA%A7%E7%94%9F%E5%91%BD%E4%B8%AD%EF%BC%88%E6%88%91%E5%8F%AA%E6%83%B3%E9%98%BB%E6%AD%A2%20DMA0%20%E4%BC%A0%E8%BE%93%EF%BC%89%E3%80%82%E6%88%91%E4%B9%8B%E5%89%8D%E5%88%86%E4%BA%AB%E7%9A%84%E9%93%BE%E6%8E%A5%E6%98%AF%E4%B8%80%E7%AF%87%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%E7%9A%84%E6%96%87%E7%AB%A0%E3%80%82%3C%2FP%3E%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EMicka%C3%ABl%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMX%20RT1170%20EVKB%20-%20Access%20policy%20behavior%20issue%20when%20trying%20to%20block%20an%20eDMA%20transfer%20using%20XRDC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148016%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253043%22%20target%3D%22_blank%22%3E%40mneroda%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%A0%E8%BF%98%E8%AE%BE%E7%BD%AE%E4%BA%86%E5%A6%82%E4%B8%8B%E4%BB%BB%E5%8A%A1%E5%90%97%EF%BC%9F%E8%AF%B7%E4%BA%88%E4%BB%A5%E6%BE%84%E6%B8%85%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eassignment.mask%20%20%3D%200xFFFFFFFFUL%3B%0A%0Aassignment.match%20%3D%200UL%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
