Hi Leo:
The watchdog interrupt grace period on the imx93 is derived from a 24Mhz clock, and the reference manual specifies a 128-cycle window before reset. However, the actual interrupt duration you measured (~57us) includes software overhead, such as interrupt latency, context switching and GPIO toggling.
If you need more time before reset, you can implement a software timer that monitors system health and gives more time for recovery.
Or you can try whether you can use a slower clock source (external 32khz if available.)
