I would like updated documentation for the IMX6ULL NAND Boot
1,506 次查看
JohnKlug
Senior Contributor I
I have seen this, and the attachments are no longer valid:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-To-use-NAND-boot-on-i-MX6UL-EVK-boar...
I noticed that this posting references U302 and U303 which are not on current schematics.
I am interested in how to configure the current Yocto build for the raw NAND (GPMI) boot.
1,492 次查看
JohnKlug
Thanks.  I did not realize there was more than one schematic.  I was looking at the board schematic, SPF-28616_C2, and what I needed to look at is SPF-29364_A1.
Also, I see there are instructions for building the NAND boot in section 5.5 of i.MX Yocto Project User's Guide.
I think I will start by trying to get the NOR to boot with U-Boot.
1,493 次查看
JohnKlug
1,502 次查看
joanxie
do you use imx6ul evk board or imx6ull? which schematic version do you refer to, refer to the cpu schematic you can find U302 and U303
1,487 次查看
JohnKlug
I am using MCIMX6ULL_EVK board and file:
MCIMX6ULL-EVK-DESIGNFILES.zip
which I downloaded from your website.
