I found spell error on auto code generation.
kenji
Hi Team
I'm using i.MXRT1170 and I found spell error on auto code generation.
II hope it will be fixed.
[Bug details]
wrong = triggerPrioirtyPolicy
correct = triggerPriorityPolicy
[IDE version I use]
gusarambula
Hello Kenji,
I agree that having to fix this typo manually is not ideal.
I haven't been able to reproduce this error, but my IDE is a slightly newer build. What I did found weird is that the version of the Config Tools integrations is very different.
Would you please provide the Peripherals Tool version and, would you please try installing a newer MCUXpresso IDE version to see if perhaps this error was already fixed in a subsequent release?
Gustavo
gusarambula
Hello Kenji,
Thank you for pointing out this typo which leads to errors when setting up the ADC.
I tried replicating it with the MCUXpresso 11.4 and the i.MXRT1170-EVK SDK 2.10.1 to no avail. Would it be possible for you to please share the steps you followed to get this error? Or does it happen any time you configure the LPADC1?
Gustavo
kenji
Hi, gusarambula-san
Bug happens always when re-config the ADC settings.
On default IDE settings, rewrite the peripherals.c is not permitted.
So, it's a little work to fix the file every time.
I hope the bug fix as soon as possible.
gusarambula
Hello Kenji,
Gustavo
kenji
Hi @gusarambula -san
I re-install the IDE. And now my Config Tool and peripheral tool version is same as yours.
But error not solved. I hope it will be fixed in the next update. Thank you.
gusarambula
Hello Kenji,
My apologies for the inconvenience of this bug. I haven't been able to reproduce it so that I can escalate to the SDK team.
Would it be possible for you to please attach your project to inspect it?
And I would like to confirm, does the same issue remain when creating a new project or importing an example on the MCUXpresso IDE?
Gustavo
kenji
Hi @Gustavo -san
This is Peripherals Tool verion I'm using.
