I.MX6Q Mic. Recording Problem!!
8,768件の閲覧回数
jasonoh
Good Day!
My name is Jason Oh from Korea(South).
I have ported android 7.1.2 successfully to our custom  i.mx6q board.
CPU       : i.MX6Q
OS         : Android 7.1.2 Nougat (N7.1.2_2.0.0, 4.9 kernel)
CODEC : WM8960
When I record microphone, it has recorded normally around 5 seconds, then errors occur.
Could someone help me to fix this problem?
If you need more infomation (schematic, source code, etc..), please tell me!
Thank You!!
*Logcat Output)
0-12 06:52:24.431   277   324 I audio_hw_primary: start_output_stream_primary... -1494403328, device 2
10-12 06:52:24.434   544   644 I MediaFocusControl:  AudioFocus  requestAudioFocus() from uid/pid 10051/1192 clientId=android.media.AudioManager@b96226f req=1 flags=0x0
10-12 06:52:24.460   277   605 W audio_hw_primary: get_input_buffer_size size = 48, channel_count = 1
10-12 06:52:24.461   277   605 W audio_hw_primary: In channels 1, rate 8000, devices 0x80000004
10-12 06:52:24.461   277   605 W audio_hw_primary: get_input_buffer_size size = 48, channel_count = 1
10-12 06:52:24.462   277  1230 I AudioFlinger: AudioFlinger's thread 0xa56833c0 ready to run
10-12 06:52:24.465   285   285 W AudioRecord: Server adjusted notificationFrames from 1024 to 160 for frameCount 2048
10-12 06:52:24.466   285  1231 I MediaPlayerService: MediaPlayerService::getOMX
10-12 06:52:24.467   285  1231 I OMXClient: MuxOMX ctor
10-12 06:52:24.467   282   297 I OMXMaster: makeComponentInstance(OMX.google.amrnb.encoder) in mediacodec process
10-12 06:52:24.470   285  1231 I MediaCodec: MediaCodec will operate in async mode
10-12 06:52:24.472   282   282 E OMXNodeInstance: setConfig(11a0038:google.amrnb.encoder, ConfigPriority(0x6f800002)) ERROR: Undefined(0x80001001)
10-12 06:52:24.472   285  1231 I ACodec  : codec does not support config priority (err -2147483648)
10-12 06:52:24.478   285   285 I MPEG4Writer: limits: 4294967295/0 bytes/us, bit rate: 12200 bps and the estimated moov size 3195 bytes
10-12 06:52:24.479   285  1227 I MediaCodecSource: MediaCodecSource (audio) starting
10-12 06:52:24.709   277   324 W audio_hw_primary: card 0, port 0 device 0x2
10-12 06:52:24.709   277   324 W audio_hw_primary: rate 44100, channel 2 period_size 0xc0
10-12 06:52:24.710   277  1230 W audio_hw_primary: in_set_parameters input_source=1;routing=-2147483644
10-12 06:52:24.711   277  1229 W audio_hw_primary: start_input_stream....
10-12 06:52:24.712   285  1227 I MediaCodecSource: MediaCodecSource (audio) started
10-12 06:52:24.717   277  1229 W audio_hw_primary: card 0, port 0 device 0x4
10-12 06:52:24.717   277  1229 W audio_hw_primary: rate 44100, channel 2 format 0, period_size 0xc0
10-12 06:52:24.726   277   324 W AudioFlinger: write blocked for 295 msecs, 4 delayed writes, thread 0xa6983640
10-12 06:52:24.767   285  1236 I MPEG4Writer: setStartTimestampUs: 9827
10-12 06:52:24.767   285  1236 I MPEG4Writer: Earliest track starting time: 9827
10-12 06:52:27.806   277   324 W audio_hw_primary: do_out_standby... -1494403328
10-12 06:52:43.248   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -1
10-12 06:52:43.248   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -1
10-12 06:52:43.248   277  1229 W audio_hw_primary: ret -1, pcm read error cannot read stream data: I/O error.
10-12 06:52:43.254   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.254   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.254   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.260   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.260   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.260   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.267   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.267   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.267   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.273   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.273   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.273   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.279   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.279   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.279   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.285   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.285   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.285   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.291   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.291   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.291   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
ラベル(5)
12 返答(返信)
7,546件の閲覧回数
ffffff2
Hi Jason,
I meet the same issue. Would you please share your solution with me?
I run android recording application and the error -16 occur.
my e-mail:  [email protected]
Thank you so much!
7,546件の閲覧回数
WeiWeiBo
Hi Jason
I meet same question, could you share some useful information with me?
My email: [email protected]
really thx
7,546件の閲覧回数
zhouhuafeng
Hi, Jason,
I meet the same issue. Could you share your solution with me? thank you so much!
7,546件の閲覧回数
huzehua1985
Hi, Jason,
I run my own recording APP for several days and the error -16 occur.
7,550件の閲覧回数
jasonoh
Hi bo.li,
This is Jason.
Please check your e-mail.
I hope it helps.
If you need more information, please let me know.
Thank you.
Jason Oh
7,550件の閲覧回数
nxf39234
Hi, Jason:
  Could you share your solution with me! Thank you so much!
  My e-mail: [email protected]
Yuan Liu
7,550件の閲覧回数
WeiWeiBo
Hi Ivy
I meet the similar question, could you provide useful information with me
my email: [email protected]
really thx
7,550件の閲覧回数
zhouhuafeng
Hi, lvy:
I meet the same issue. Could you share this issue solution with me? thank you.
7,549件の閲覧回数
jasonoh
This is Jason Oh.
I have solved this issue.
1. S/W : Driver update.
2. H/W : 1 point ECO.
If you have any trouble like this, please tell me.
Thanks everyone.
Jason Oh.
Attached file is my solution.
I hope this help you.
Jason Oh.
7,549件の閲覧回数
cxx2050
Hi, Jason,
I meet the same issue. Could you share your solution with me? Many thanks!
I run my own recording APP for several days and the error occur.
7,549件の閲覧回数
bo_li
Hi Jason,
I meet the same issue.Could you share your solution with me? Thank you.
7,549件の閲覧回数
Hi Jason
please check Android audio codec porting guide on
How to port new audio codec into Android.doc
