NTP Server Synchronization on LTIB 2.6.35 build
3,610件の閲覧回数
ijazfazily
I need to add support for NTP server synchronization on LTIB 2.6.35 build. Please let me know how to proceed with the same.
Iju
ラベル(2)
5 返答(返信)
3,462件の閲覧回数
Rita_Wang
I do not know which product you are using. For our now product we do not use the LTIB no more, we use the yocto. For the yocto setting you can refer to https://community.nxp.com/message/363069
3,462件の閲覧回数
ijazfazily
I really appreciate your response. We have network card, which has i.MX283 application processor running LTIB 2.6.35 build. This is actually a feature addition of an existing product. Please let me know if any reference links available for this requirement.
Thank you.
3,462件の閲覧回数
Rita_Wang
I will try my best to found some reference for you.
3,462件の閲覧回数
ijazfazily
Could you please update ?
ijaz
3,463件の閲覧回数
jimmychan
1. You may find the source code of your NTP server software package. (.tar.gz file)
2. Create a .spec file in the LTIB for configure,compile,deploy of this software package. You can refer to other .spec as an example.
3. Or you can compile the source code by the ARM toolchain and then install/copy the executable files to the rootfs directly.
