I.MX6 using HAB key in kernel
1,815 次查看
zc_tee
Hi all,
Is there any example where i can use the private key that was fused inside the i.mx6 chip (for secure boot) to do some authentication of some files during kernel boot up?
I had managed to fused the key into i.mx6 chip, and managed to authenticate u-boot (from boot ROM) and kernel (from u-boot). However, i have no idea how to continue to use the key in kernel to further authenticate some files in filesystem.
Any help is appreciated.
Thank you.
Tee
标签 (2)
1,483 次查看
joanxie
I send the document and application note to you for reference,
if you don't think this is enough,  do you mind creating a ticket, then I sent the mail to you. because this is security part, I'm not sure I can share these information publicly,
<Encrypted U-boot Example >.
<http://cache.nxp.com/files/32bit/doc/app_note/AN4581.pdf?fsrch=1&sr=1&pageNum=1 >.
<How to submit a new question for NXP Support >
1,483 次查看
zc_tee
Anybody has answer for this?
Tee
