I.MX6 PCIe power-on initialization sequence
6,287 次查看
jiandong1
Hi,NXP:
We have measured the PCIe power-on initialization sequence of EVK(FW version:LF_v5.15.32-2.0.0_images_IMX6QPDLSOLOX),PCIE_RESET active before PCIE_CLK about 1ms,details as attachment;
According to the PCIe design specification,when PCIE_CLK is stable,PCIE_RESET just active ,now PCIE_RESET active before PCIE_CLK,so I want you to clarify the issue,thanks for your reply~
6 回复数
6,043 次查看
jiandong1
Done,Thanks~
6,047 次查看
jiandong1
Done,Thanks ~
6,269 次查看
Zhiming_Liu
Hi @jiandong1
This is Synopsys DesignWare PCI IP requirements.
Best Regards
Zhiming
6,266 次查看
jiandong1
Thank you~
By the way,could you support some related files for study?
6,264 次查看
Zhiming_Liu
The IP SPEC can't share.
6,262 次查看
jiandong1
ok,thanks~
