I.MX6: Android register access tool
1,432 次查看
sureshrao
Hi, All,
The attached tool can be used to access register from android terminal window.
How to Build:
Create directory 'regaccess'  under 'external' directory in the android root directory, copy the attached files and build android images.  The built system image will now include 'regaccess' utility to read/write registers in android.
Syntax:
     $ regaccess <register> [val]
To read IOMUX register located at 0x20e0000
$ regaccess 0x20e0000
To write to 0x0 to register 0x20e0000
$ regaccess 0x20e00000 0x0
Hope this helps in debugging issues from android.
Suresh
Original Attachment has been moved to: Android.mk.zip
Original Attachment has been moved to: regaccess.c.zip
标签 (2)
标记 (3)
0 回复数
