I.MX53 thermal cycle failure debugging tools
1,619件の閲覧回数
okernytskyy
We are investigating iMX53 system failures during thermal cycle test (-20C, +60C), and the most common failure symptom - CPU stocked and unable to boot up. We want to determine at which point it stopped working, what may cause it, and we hope that JTAG will help.
Which JTAG debugger (Model, Manufacturer, Part Number) can we use for it and why?
It seems that NXP does not offer JTAG debugger for i.MX systems.
We have BDI-3000, but it is not supported anymore and may require i.MX module that we don't have.
We also have SEGGER ARM JTAG flesher, but it seems that it is intended for programming only.
Please advise.
1,490件の閲覧回数
Yuri
  The following may be helpful:
https://www.nxp.com/files-static/wireless_comm/doc/brochure/BRTOOLENABLECO.pdf
Yuri.
1,490件の閲覧回数
Bio_TICFSL
Hi Oleh,
You can try with RealView ICE,
ARM Information Center
regards
