How to get iMX6 solox MAPBGA529 Orcad symbol?
Thank you so much!
OK,thank you very much for your reply
Hi lin
I am afraid such design was not publicly released, suggest try to obtain
through local marketing office.
Hi igor
Thank you very much for your reply!
It should be that I understand the wrong, how should I understand the "Package Termination Count", is this not the same as the number of BGA device balls?As shown in the figure below, the Package Termination Count is 529, but the package is BGA400.
more accurate package info can be found in i.MX6SX Datasheet
Figure 1. Part Number Nomenclature—i.MX 6SoloX:
https://www.nxp.com/docs/en/data-sheet/IMX6SXAEC.pdf
