I.MX RT1176 Serial Downloader Rts - Cts support ?
2,191件の閲覧回数
koray692
I am using rom bootloader using uart-1 and it works fine but I want to use it with half duplex rs485, so I need RTS - CTS pin, does rom bootloader support RTS - CTS?
Best regards.
2,120件の閲覧回数
koray692
Thank you for your answer.And I guess, probably I can program by using full dublex rs-422 or rs-232.
2,160件の閲覧回数
Bio_TICFSL
the bootloader is not programmed to half duplex rs485, but if your program this you can have it.
