Hybrid Automotive OS(Linux + Android)
4,748 次查看
himabindu
Hi Team,
       I  have generated a yocto  Linux  AGL image for imx8mq evk board. Now how to make common kernel with automotive changes done using yocto such that linux+android  will be supported. Based on some input like android, android has to boot and if input is linux then linux has to boot.
Is it possible to make a common kernel(Linux+ Android) with automotive changes for IMX8M evk board.
Thanks & Regards,
C.Himabindu.
5 回复数
4,725 次查看
himabindu
Hi Team,
Can we try the imx8qm-mek images on the imx8mq-evk board .Will the board poweron.
Thanks & Regards,
C.Himabindu
4,714 次查看
art
No, it is not possible to run the imx8qm-mek image on the i.MX8MQuad EVK board, since the hardware (including processors) is absolutely incompatible.
Artur
4,725 次查看
himabindu
Thankyou for your response
4,731 次查看
art
Q. Is it possible to make a common kernel(Linux+ Android) with automotive changes for IMX8M evk board.
A. Seems that nobody has tried to do it so far.
The Embedded Linux and Android Auto BSPs, supported by NXP, are available separately:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
https://www.nxp.com/design/software/embedded-software/software-technology-for-android-auto:ANDROID-A...
Moreover, only the i.MX8QuadMax SoC is currently supported for Android Auto by NXP.
Artur
3,271 次查看
Hassan_Zafirul
I hope someone has done this; could you please provide the links? I'm seeking for this type of solution.
