How use QSPI Flash on MIMXRT1064-EVK
1,508 次查看
hiro33
Hello
I want to write a program to QSPI Flash (IS25WP064AJBLE) of MIMEX RT1064-EVK and execute it.
Can I run the program from an external FLash?
1 The program starts at 0x70000000, but I don't know how to start at 0x60000000.
2 Does i.MX RT have a memory-mapped mode for QSPI?
Please give me advice.
Best Regards.
1,484 次查看
hiro33
Hi Kerry
It went well.
Thank you for your help!
Best Regards
1,500 次查看
kerryzhou
Hi @hiro33
  Please refer to this post:
https://community.nxp.com/t5/i-MX-RT/iMXRT1064-External-Flash-XIP-Support/td-p/1379712
 It is the same question, and we already share the related code.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
1,485 次查看
hiro33
Hi Kerry
It went well.
Best Regards
