How to work with touch screen ?
8,459件の閲覧回数
snan1z
Hi all,
I want to use my MCIMX28LCD Seiko 4.3" touch screen. but i can't. I tried to enable it from kernel configuration "Device Drivers/input device support / touch screens / MXS LRADC-based touchscreen" but it fails.
Please kindly help
Sinan
12 返答(返信)
7,253件の閲覧回数
Nico
I'm using a touchscreen TSC2006 with LTIB (linux 2.6.35 ) on iMX28.
how to calibrate the touch screen?
7,253件の閲覧回数
snan1z
Yi,
Can you use ts_calibrate command ?
7,254件の閲覧回数
YiLi
A related question, any one know how to configure the touch screen on ubuntu. I can see the pen up/down event from dmesg but could not press down any icon.
cat /dev/input/
event0 event2 event4 mice mouse1
event1 event3 event5 mouse0
Yi
7,253件の閲覧回数
snan1z
Vladan,
I have "ts0, event0, mice" under /dev/input so i tried it with ts0 and event0 but i cant use touch screen with Qt.
Richard,
i didn't try OBDS.SB, but i think OBDS.SB tests only touch screen, not with Qt.
there may be problem with Qt/demos ? ( i used /demos/embedded/fluidlauncher to test like "./fluidlauncher -qws" )
7,253件の閲覧回数
RichardXiao
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX28_SW&fr=g
Sinan Emre Kutlu said:
Vladan,
I tried it with "/dev/input/ts0" and "/dev/input/event0", but nothing happened.
Richard,
What is it? i searched from google but it outputs nothing.
7,253件の閲覧回数
VladanJovanovic
Sorry, my mistake.
export TSLIB_TSDEVICE=/dev/input/event1
export QWS_MOUSE_PROTO=tslib:/dev/input/event1
First one tells tslib what to use as touch input. Second one tells Qt what to use as input.
7,253件の閲覧回数
snan1z
Vladan,
Richard,
7,253件の閲覧回数
RichardXiao
Test by OBDS.SB
7,253件の閲覧回数
VladanJovanovic
Did you run "export TSLIB_TSDEVICE=/dev/input/event2" before starting the Qt app?
7,253件の閲覧回数
snan1z
Ok, i solved the problem, but i got a newer one. i can calibrate touch screen and test with "ts_calibrate","ts_test". but i cant use it with QT. In qt conf, i add -qt-mouse-tslib option but i couldn't use it.
7,253件の閲覧回数
BryanJI
PLZ copy your boot message then you can know what's wrong.
There are too many reasons could cause this.
Using dmesg to check
7,253件の閲覧回数
snan1z
also i cant see it under /dev/input
