How to use the touch usb and the host PC usb for adb at the same time in iMX8QM MEK Board
1,321 次查看
hyun-moyang
Hi All,
I am trying to enable the touch USB and the host PC USB for adb at the same time in iMX8QM MEK Board in the android auto platform which version is android-11.0.0_1.1.0-AUTO.
When I am trying to use the touch USB and the host PC USB for adb at the same time and when I use the USB hub with USB-C type, I have ONLY found the operation of touch USB, the host PC USB  for adb didn't run.
I would like to know how to use the touch USB and the host PC USB for adb at the same time in iMX8QM MEK.
Please make me advise on how to use the USB devices at the same time.
Best Regards
HM
1,312 次查看
IvanRuiz
Please accept my apologies but it will not be possible to use both at the same time unless it has two USB device modules, otherwise, the performance will be very slow when using ADB.
BR,
Ivan.
1,306 次查看
hyun-moyang
Hi Aldo,
Thanks for your comments
I have resolved this issue as to your guide
Best Regards
HM
