Hi ,
i have configured and followed the above procedure. now i can able to load the uImage through on board ethernet adapter .
but the problem is while booting up I am getting the below boot message i cant able to mount my rootfs
eth0: enable RMII gasket
net eth1: SMSC911x/921x identified at 0xc48fc000, IRQ: 256
Sending DHCP requests ...... timed out!
IP-Config: Retrying forever (NFS root)...
Please kindly let me know what should i do to mount the rfs using FEC0.
NOTE: if i am using debug board eth adapter means i can able to load the OS fully.
Guru
