How to use LPUART2 polling example on CM33?
已解决
跳至解决方案
5,450 次查看
wendy-liu
Dear all,
      I want to use lpuart polling example on SDK, the demo_example is LPUART1, but I want to use LPUART2.
     Then I add pin_mux and set the clock, then debug console print as below:
ASSERT ERROR " (reg & PCC_CLKCFG_PR_MASK) != 0UL ": file "/home/wendy/workspace/imx8ulp-m33/devices/MIMX8UD7/drivers/fsl_clock.c" Line "300" function name "CLOCK_SetIpSrc"
    This is my add:
void BOARD_InitHardware(void)
    +CLOCK_SetIpSrc(kCLOCK_Lpuart2, kCLOCK_Pcc2BusIpSrcFusionDspBus);
void BOARD_InitPins(void) {                                /*!< Function assigned for the core: Cortex-M33[cm33] */
    IOMUXC_SetPinMux(IOMUXC_PTA10_LPUART1_TX, 0U);
    IOMUXC_SetPinConfig(IOMUXC_PTA10_LPUART1_TX,
                        IOMUXC_PCR_PE_MASK |
                        IOMUXC_PCR_PS_MASK);
    IOMUXC_SetPinMux(IOMUXC_PTA11_LPUART1_RX, 0U);
    IOMUXC_SetPinConfig(IOMUXC_PTA11_LPUART1_RX,
    +IOMUXC_SetPinMux(IOMUXC_PTB2_LPUART2_TX , 0U);
    +IOMUXC_SetPinConfig(IOMUXC_PTB2_LPUART2_TX ,
    +                    IOMUXC_PCR_PE_MASK |
    +                    IOMUXC_PCR_PS_MASK);
    +IOMUXC_SetPinMux(IOMUXC_PTB3_LPUART2_RX, 0U);
    +IOMUXC_SetPinConfig(IOMUXC_PTB3_LPUART2_RX,
Looking forward to your reply!
Thanks!
标签 (1)
1 解答
5,142 次查看
danielchen
Thanks for your update.  please follow below thread for this question.  Re: imx8ulp m33 core gpio - NXP Community
在原帖中查看解决方案
13 回复数
5,432 次查看
wendy-liu
I add clock in ATF: plat/imx/imx8ulp/imx8ulp_bl31_setup.c:
mmio_write_32(0x28102000+ 0x2c, 0x80000000);
But it doesn't work
5,412 次查看
danielchen
Hi @wendy-liu :
LPUART2 is in DPS domain,  is designed for DSP core, not for CM33.  CM33 can not control it.
please check the reference manual.
5,411 次查看
danielchen
LPUART0 and LPUART1 are in CM33 real time domain.
5,402 次查看
wendy-liu
I know, but how to enable LPUART2 on DSP domain?
5,384 次查看
danielchen
Hi @wendy-liu :
The error message is from function CLOCK_SetIpSrc, can you debug and check the value of reg?
5,374 次查看
wendy-liu
The reg of PCC_LPUART2 is always 0.
5,349 次查看
danielchen
Please try below lines.
    const cgc_rtd_sys_clk_config_t g_sysClkConfigFroSource = {
    .divCore = 0, /* Core clock divider. */
    .divBus  = 1, /* Bus clock divider. */
    .divSlow = 3, /* Slow clock divider. */
    .src     = kCGC_RtdSysClkSrcFro, /* System clock source. */
    .locked  = 0, /* Register not locked. */
    CLOCK_SetFusionSysClkConfig(&g_sysClkConfigFroSource);
     BOARD_InitPins();
     BOARD_BootClockRUN();
     BOARD_InitDebugConsole();
     Fusion_Init();
     BOARD_SetTrdcGlobalConfig();
    rate = CLOCK_GetFreq(kCLOCK_FusionDspBusClk);
    PRINTF("The rate is 0x%x. \r\n", rate);
Any support, information, and technology (“Materials”) provided by NXP are provided AS IS, without any warranty express or implied, and NXP disclaims all direct and indirect liability and damages in connection with the Material to the maximum extent permitted by the applicable law. NXP accepts no liability for any assistance with applications or product design.  Materials may only be used in connection with NXP products. Any feedback provided to NXP regarding the Materials may be used by NXP without restriction.
5,342 次查看
wendy-liu
I have tried it.
The rate is 0x5b8d800. My M core and A core don't start normally...
There is my patch.
5,166 次查看
danielchen
Hi @wendy-liu :
Did you solve this issue now?
5,160 次查看
wendy-liu
I have already enabled LPUART2, but I'm having some issues with API “LPUART_WriteBlocking” I'm currently using.
5,143 次查看
danielchen
5,377 次查看
wendy-liu
yes, I read reg of LPUART1  and LPUART2 CLOCK, result is 0xd2000000 and 0.
Now, I 'm working with TRDC for eDMA access.
I add some configutation in
voidBOARD_SetTrdcGlobalConfig(void) as below:
        /* non secure state can access lpuart2(PBridge2 slot 11, T-MBC3) for eDMA0 */
        mbcBlockConfig.memoryAccessControlSelect = TRDC_MBC_ACCESS_CONTROL_POLICY_ALL_INDEX;
        mbcBlockConfig.nseEnable                 = true; /* non secure state can access the block for eDMA0 */
        mbcBlockConfig.mbcIdx                    = 3U;   /* MBC3 */
        mbcBlockConfig.domainIdx                 = TRDC_DMA0_DOMAIN_ID; /* MBC3_DOM0 */
        mbcBlockConfig.slaveMemoryIdx            = 0U;                  /* MBC3_DOM0_MEM0 */
        mbcBlockConfig.memoryBlockIdx            = 11U;                 /* MBC3_DOM0_MEM0_BLK_CFG_W11 */
        TRDC_MbcSetMemoryBlockConfig(TRDC, &mbcBlockConfig);
But the result is that I don't read reg of LPUART2[PCC_REG(kCLOCK_Lpuart2)]. It means the Peripheral is not present...
Is there any new information on this?
5,382 次查看
danielchen
did you initialize the DSP core (Fusion_Init) before you call CLOCK_SetIpSrc?
%3CLINGO-SUB%20id%3D%22lingo-sub-2080282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%8A%E6%95%AC%E7%9A%84%E5%90%84%E4%BD%8D%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%9C%A8%20SDK%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20lpuart%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%8Cdemo_example%20%E6%98%AF%20LPUART1%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20LPUART2%E3%80%82%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E6%B7%BB%E5%8A%A0pin_mux%E5%B9%B6%E8%AE%BE%E7%BD%AE%E6%97%B6%E9%92%9F%EF%BC%8C%E7%84%B6%E5%90%8E%E8%B0%83%E8%AF%95%E6%8E%A7%E5%88%B6%E5%8F%B0%E6%89%93%E5%8D%B0%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%96%AD%E8%A8%80%E9%94%99%E8%AF%AF%E2%80%9C%EF%BC%88reg%EF%BC%86PCC_CLKCFG_PR_MASK%EF%BC%89%EF%BC%81%3D%200UL%E2%80%9D%EF%BC%9A%E6%96%87%E4%BB%B6%E2%80%9C%2Fhome%2Fwendy%2Fworkspace%2Fimx8ulp-m33%2Fdevices%2FMIMX8UD7%2Fdrivers%2Ffsl_clock.c%E2%80%9D%E8%A1%8C%E2%80%9C300%E2%80%9D%E5%87%BD%E6%95%B0%E5%90%8D%E7%A7%B0%E2%80%9CCLOCK_SetIpSrc%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E8%A1%A5%E5%85%85%EF%BC%9A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EBOARD_InitHardware%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2BCLOCK_SetIpSrc%3C%2FSPAN%3E%3CSPAN%3E(kCLOCK_Lpuart2%2C%20%3C%2FSPAN%3E%3CSPAN%3EkCLOCK_Pcc2BusIpSrcFusionDspBus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%7D%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EBOARD_InitPins%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*!%26lt%3B%20%E4%B8%BA%E6%A0%B8%E5%BF%83%E5%88%86%E9%85%8D%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%9ACortex-M33%5Bcm33%5D%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTA10_LPUART1_TX%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinConfig%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTA10_LPUART1_TX%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PE_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PS_MASK%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTA11_LPUART1_RX%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinConfig%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTA11_LPUART1_RX%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PE_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PS_MASK%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTB2_LPUART2_TX%3C%2FSPAN%3E%3CSPAN%3E%20%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinConfig%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTB2_LPUART2_TX%3C%2FSPAN%3E%3CSPAN%3E%20%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PE_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PS_MASK%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinMux%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTB3_LPUART2_RX%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_SetPinConfig%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PTB3_LPUART2_RX%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PE_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%2B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIOMUXC_PCR_PS_MASK%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%9C%9F%E5%BE%85%E4%BD%A0%E7%9A%84%E7%AD%94%E5%A4%8D%EF%BC%81%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2080282%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX8ULP%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%9B%B4%E6%96%B0%E3%80%82%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E4%B8%BB%E9%A2%98%E5%9B%9E%E7%AD%94%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2Fimx8ulp-m33-core-gpio%2Fm-p%2F2083462%2Fhighlight%2Ffalse%2Fpage%2F2%22%20target%3D%22_blank%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Aimx8ulp%20m33%20%E6%A0%B8%E5%BF%83%20gpio%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%90%AF%E7%94%A8%E4%BA%86%20LPUART2%EF%BC%8C%E4%BD%86%E6%88%91%3CSPAN%3E%20%E5%BD%93%E5%89%8D%E4%BD%BF%E7%94%A8%E7%9A%84%20API%E2%80%9C%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3E%20LPUART_WriteBlocking%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%3CSTRONG%3E%20%E2%80%9D%20%E9%81%87%E5%88%B0%3C%2FSTRONG%3E%20%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2084111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2084111%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246604%22%20target%3D%22_blank%22%3E%40wendy-liu%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E7%8E%B0%E5%9C%A8%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081651%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%9D%E8%AF%95%E8%BF%87%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E9%80%9F%E7%8E%87%E4%B8%BA0x5b8d800%E3%80%82%E6%88%91%E7%9A%84%20M%20%E6%A0%B8%E5%92%8C%20A%20%E6%A0%B8%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8......%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E8%A1%A5%E4%B8%81%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081599%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3Econst%20cgc_rtd_sys_clk_config_t%20g_sysClkConfigFroSource%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E.divCore%20%3D%200%2C%20%2F*%20%E6%A0%B8%E5%BF%83%E6%97%B6%E9%92%9F%E5%88%86%E9%A2%91%E5%99%A8%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E.divBus%20%3D%201%2C%20%2F*%20%E6%80%BB%E7%BA%BF%E6%97%B6%E9%92%9F%E5%88%86%E9%A2%91%E5%99%A8%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E.divSlow%20%3D%203%2C%20%2F*%20%E6%85%A2%E6%97%B6%E9%92%9F%E5%88%86%E9%A2%91%E5%99%A8%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20.src%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3D%20kCGC_RtdSysClkSrcFro%2C%20%2F*%20System%20clock%20source.%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E.locked%20%3D%200%2C%20%2F*%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%9C%AA%E9%94%81%E5%AE%9A%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20CLOCK_SetFusionSysClkConfig(%26amp%3Bg_sysClkConfigFroSource)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E6%9D%BF%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%95%E8%84%9A%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E6%97%B6%E9%92%9F%E8%BF%90%E8%A1%8C%EF%BC%88%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20BOARD_InitDebugConsole()%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Fusion_Init()%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BBOARD_SetTrdcGlobalConfig()%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rate%20%3D%20CLOCK_GetFreq(kCLOCK_FusionDspBusClk)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPRINTF(%22%E6%B1%87%E7%8E%87%E4%B8%BA%200x%25x%E3%80%82%5Cr%5Cn%22%2C%20%E9%80%9F%E7%8E%87)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3BCLOCK_SetIpSrc(kCLOCK_Lpuart2%2C%20kCLOCK_Pcc2BusIpSrcFusionDspBus)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3ENXP%20%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BB%BB%E4%BD%95%E6%94%AF%E6%8C%81%E3%80%81%E4%BF%A1%E6%81%AF%E5%92%8C%E6%8A%80%E6%9C%AF%EF%BC%88%E2%80%9C%E6%9D%90%E6%96%99%E2%80%9D%EF%BC%89%E5%9D%87%E6%8C%89%E2%80%9C%E5%8E%9F%E6%A0%B7%E2%80%9D%E6%8F%90%E4%BE%9B%EF%BC%8C%E4%B8%8D%E9%99%84%E5%B8%A6%E4%BB%BB%E4%BD%95%E6%98%8E%E7%A4%BA%E6%88%96%E6%9A%97%E7%A4%BA%E7%9A%84%E4%BF%9D%E8%AF%81%EF%BC%8C%E5%B9%B6%E4%B8%94%20NXP%20%E5%9C%A8%E9%80%82%E7%94%A8%E6%B3%95%E5%BE%8B%E5%85%81%E8%AE%B8%E7%9A%84%E6%9C%80%E5%A4%A7%E8%8C%83%E5%9B%B4%E5%86%85%E4%B8%8D%E6%89%BF%E6%8B%85%E4%B8%8E%E6%9D%90%E6%96%99%E7%9B%B8%E5%85%B3%E7%9A%84%E6%89%80%E6%9C%89%E7%9B%B4%E6%8E%A5%E5%92%8C%E9%97%B4%E6%8E%A5%E8%B4%A3%E4%BB%BB%E5%92%8C%E6%8D%9F%E5%AE%B3%E3%80%82NXP%20%E5%AF%B9%E4%BB%BB%E4%BD%95%E4%B8%8E%E5%BA%94%E7%94%A8%E6%88%96%E4%BA%A7%E5%93%81%E8%AE%BE%E8%AE%A1%E6%9C%89%E5%85%B3%E7%9A%84%E5%8D%8F%E5%8A%A9%E4%B8%8D%E6%89%BF%E6%8B%85%E4%BB%BB%E4%BD%95%E8%B4%A3%E4%BB%BB%E3%80%82%E6%9D%90%E6%96%99%E4%BB%85%E5%8F%AF%E4%B8%8E%20NXP%20%E4%BA%A7%E5%93%81%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8F%AF%E4%B8%8D%E5%8F%97%E9%99%90%E5%88%B6%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%E5%90%91%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8F%90%E4%BE%9B%E7%9A%84%E6%9C%89%E5%85%B3%E6%9D%90%E6%96%99%E7%9A%84%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPCC_LPUART2%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E5%A7%8B%E7%BB%88%E4%B8%BA0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%3CSPAN%3E%E6%88%91%E8%AF%BB%E5%8F%96%E4%BA%86LPUART1%E5%92%8CLPUART2%E6%97%B6%E9%92%9F%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%98%AF0xd2000000%E5%92%8C0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%B8%8E%20TRDC%20%E5%90%88%E4%BD%9C%3CSPAN%3E%E5%AE%9E%E7%8E%B0%20eDMA%20%E8%AE%BF%E9%97%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSTRONG%3EvoidBOARD_SetTrdcGlobalConfig%EF%BC%88%E6%97%A0%E6%95%88%EF%BC%89%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E9%9D%9E%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AE%20eDMA0%20%E7%9A%84%20lpuart2%EF%BC%88PBridge2%20%E6%8F%92%E6%A7%BD%2011%EF%BC%8CT-MBC3%EF%BC%89*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EmemoryAccessControlSelect%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ETRDC_MBC_%E8%AE%BF%E9%97%AE%3C%2FSPAN%3E%3CSPAN%3E%E6%8E%A7%E5%88%B6%E7%AD%96%E7%95%A5_%E5%85%A8%E9%83%A8%E7%B4%A2%E5%BC%95%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3EnseEnable%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Etrue%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E9%9D%9E%E5%AE%89%E5%85%A8%E7%8A%B6%E6%80%81%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AE%20eDMA0%20%E7%9A%84%E5%9D%97%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EmbcIdx%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E3U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%2F*%20MBC3%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EdomainIdx%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ETRDC_DMA0_DOMAIN_ID%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%2F*%20MBC3_DOM0%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EslaveMemoryIdx%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%2F*%20MBC3_DOM0_MEM0%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EmemoryBlockIdx%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E11U%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%2F*%20MBC3_DOM0_MEM0_BLK_CFG_W11%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3ETRDC_MbcSetMemoryBlockConfig%3C%2FSPAN%3E%3CSPAN%3E(TRDC%2C%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3EmbcBlockConfig%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%BD%86%E7%BB%93%E6%9E%9C%E6%98%AF%E6%88%91%E6%B2%A1%E6%9C%89%E8%AF%BB%E5%8F%96LPUART2%5B%20%3CSTRONG%3EPCC_REG(%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3EkCLOCK_Lpuart2)%3C%2FSTRONG%3E%20%5D%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%3CSTRONG%3E%E3%80%82%3C%2FSTRONG%3E%3CSPAN%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E4%B8%8D%E5%AD%98%E5%9C%A8%E2%80%A6%E2%80%A6%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSTRONG%3E%E8%BF%99%E6%96%B9%E9%9D%A2%E6%9C%89%E6%96%B0%E7%9A%84%E6%B6%88%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FSTRONG%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081462%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E8%B0%83%E7%94%A8%3CSPAN%3ECLOCK_SetIpSrc%20%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%86%20DSP%20%E6%A0%B8%E5%BF%83%EF%BC%88Fusion_Init%EF%BC%89%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2081459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2081459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246604%22%20target%3D%22_blank%22%3E%40wendy-liu%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E6%9D%A5%E8%87%AA%E5%87%BD%E6%95%B0CLOCK_SetIpSrc%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%B0%83%E8%AF%95%E5%B9%B6%E6%A3%80%E6%9F%A5reg%E7%9A%84%E5%80%BC%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielchen_0-1744786773504.png%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielchen_0-1744786773504.png%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F333392i396C304C529BC4E5%2Fimage-dimensions%2F600x38%3Fv%3Dv2%22%20width%3D%22600%22%20height%3D%2238%22%20role%3D%22button%22%20title%3D%22danielchen_0-1744786773504.png%22%20alt%3D%22danielchen_0-1744786773504.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2080674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E4%BD%95%E5%9C%A8%20DSP%20%E5%9F%9F%E4%B8%8A%E5%90%AF%E7%94%A8%20LPUART2%20%E5%91%A2%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2080593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELPUART0%20%E5%92%8C%20LPUART1%20%E4%BD%8D%E4%BA%8E%20CM33%20%E5%AE%9E%E6%97%B6%E5%9F%9F%E4%B8%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2080589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F246604%22%20target%3D%22_blank%22%3E%40wendy-liu%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELPUART2%20%E4%BD%8D%E4%BA%8E%20DPS%20%E5%9F%9F%EF%BC%8C%E6%98%AF%E4%B8%BA%20DSP%20%E6%A0%B8%E5%BF%83%E8%AE%BE%E8%AE%A1%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%B8%BA%20CM33%20%E8%AE%BE%E8%AE%A1%E7%9A%84%E3%80%82CM33%E6%97%A0%E6%B3%95%E6%8E%A7%E5%88%B6%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielchen_0-1744702508601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielchen_0-1744702508601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F333114i810FA7EAD9502525%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22danielchen_0-1744702508601.png%22%20alt%3D%22danielchen_0-1744702508601.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2080406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%9C%A8%20CM33%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20LPUART2%20%E8%BD%AE%E8%AF%A2%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2080406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%3CSPAN%3E%E5%9C%A8ATF%E4%B8%AD%E6%B7%BB%E5%8A%A0%E6%97%B6%E9%92%9F%EF%BC%9Aplat%2Fimx%2Fimx8ulp%2Fimx8ulp_bl31_setup.c%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Emmio_write_32%EF%BC%880x28102000%2B0x2c%EF%BC%8C0x80000000%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E
