How to use Config Tools for i.MX v7
1,639件の閲覧回数
hiroki_c_hashim
Dear all
I have a question. Please tell me know.
In Config Tools for i.MX v7 , there are the following items.
Among these are "Reset" and "NoInit".
When should these be set?
3 返答(返信)
1,531件の閲覧回数
gusarambula
Hello Hiroki Hashimoto,
I’m still waiting for further information on why these options have been added, but both “reset” and “Noinit” would result on the registers keeping their reset values.
I will let you know as soon as I have more information.
1,531件の閲覧回数
gusarambula
I received confirmation from our experts on how these options work:
In Config Tools for i.MX there is no difference in Pins tool generated code for "No init" and "Reset" in the pin configuration. No C code for modification is generated for these options.
However, this is true only when all electrical properties are displayed in italic (means after-reset). When anything is set to user-specified value (displayed as non-italic) then generated code may include setting also for other bit-fields of non-zero values for electrical properties configured in given register. This is how the code generation script handles pin routing for i.MX devices.
I hope this information helps!
1,531件の閲覧回数
gusarambula
The documentation has not much details on these options. I’m investigating and I’ll let you know as soon as I have more information.
