How to upgrade OpenCV lib version
1,706 次查看
xu_ji1
I want to update the Opencv version 4.0.2 in i.MX8 linux 2.3.0 Yocto release to version 4.2.0 in i.MX8 linux 5.4.3 Yocto release.
How to do,pls give guide
1,647 次查看
joanxie
you need to porting new GPU by yourself, you need to change the layer file, but I don't suggest you to do this, because gpu related many other packages and kernel,  if you use newer version gpu on old bsp version we didn't test, I'm not sure if you will get any issue
1,647 次查看
xu_ji1
why need porting new GPU?I only change opencv bb to 4.2.0 in OpenCV folder,is it ok?
1,647 次查看
joanxie
I'm not sure for this, because many packages are related, maybe you can try it
