Hello. I'm working with freeRtos using MCUxpresso and RT1176. I'm trying to understand how to work with the heap usage of freertos. My question is if below each function, the values allocated after it are related to the function or can be other allocations. For example, in the following image I have two functions and below them is an allocated value and some free values. Are they related to the function? Thank you.
已解决! 转到解答。
Hi @andréluis ,
The Task TCB is a data structure allocated by FreeRTOS for each task, used to store critical information such as the task's runtime state, priority, stack information, and context.
The "Allocated" refers to heap memory allocated through pvPortMalloc, as well as resources occupied by operating system services (such as semaphores, queues, timers, etc.).
The TCB and "Allocated" are distinct concepts with no direct relationship.
Wish it helps you.
Wish you a nice day!
Best Regards
MayLiu
Hi @andréluis ,
Thank you so much for your interest in our products and for using our community.
I think your question is related to the FreeRTOS memory management algorithm.
FreeRTOS provides a total of 5 dynamic memory management algorithms, heap_1.c, heap_2.c, heap_3.c, heap_4.c, and heap_5.c.
So could you please check which memory management algorithm is in your project.
I also would like give you a FreeRTOS link to you.
FreeRTOS heap memory management - FreeRTOS™
Wish it helps you.
Best Regards
MayLiu
Hi @andréluis ,
Wish it helps you.
Best Regards
MayLiu
