How to train with custom models on eIQ software
jasonliu1
Hi all,
I'm trying to train a custom model on the eIQ software recently, I downloaded a tflite model(a .tflite file) from the internet and I was planning on training that model on the software. However, I looked at the eIQ user manual about "user models" but I'm still confused, how should I start training with that download model? Thanks.
mgandhi
@Bio_TICFSL I'm interested in training custom models in the eIQ portal also. Unfortunately, the above hint doesn't make any sense to me.
I have the eIQ portal software installed and a data set imported.  I can train off the base models and validate on a remote target.
When I select the User Model button I get a blank screen. See attached screenshot. Is there a process for getting a custom model into the eIQ portal? I haven't found it in the documentation.
Bio_TICFSL
Hello jasonliu1,
You choose MLIR as tflite converter. I will recommend to use TOCO instead.
Thank you.
