How to enable dropbear SSH server on a i.MX8 Mini
已解决
跳至解决方案
3,625 次查看
robiwan
I have a setup with the iMX8 Mini running was is said as "NXP i.MX Release Distro 5.4-zeus".
SSH seems to be disabled by default, and dropbear seems to be available. But I'm having no luck trying to enable dropbear through systemd.
Help?
标签 (1)
1 解答
3,619 次查看
robiwan
Ok, it seems the problem was that I had setup a static IP address (via systemd) and the netmask was incorrect, so dropbear.socket failed to start. With correct netmask, problem is resolved.
在原帖中查看解决方案
1 回复
3,620 次查看
robiwan
