How to test the GPU of imx
2,003 次查看
westbrook
Hi Guys,
I am using imx6 solo with X11, kernel 4.9.11, gpu driver 6.2.2 in kernel, and I add following gpu packages to filesystem:
imx-gpu-viv-6.2.2
gpu-viv-g2d-6.2.2
xf86-video-imx-viv-6.2.2.p0
From /var/log/Xorg.0.log, I can see that the GPU driver loaded successfully. I want to know, how to test the GPU functions, it should be some demos?
Thank you in advance.
BR,
Xiao
1,709 次查看
igorpadykov
Hi Xiao
one can test with gpu unit test:
imx-test.git - i.MX Driver Test Application Software
1,709 次查看
westbrook
Hi Igor,
Thanks for your quick reply, I will try this tool.
Xiao
