How to successfully execute a script from init.rc
2,286件の閲覧回数
Shanga
We are using the i.MX8MP EVK and are trying to add a script to run after boot or after file system.we tried the below on  init.rc:
on property:sys.boot_completed=1
    start initAsic
service initAsic /system/xbin/script.sh
    seclabel u:r:init:s0
    user root
    group root
    oneshot
    disabled
The script's contents are,
echo "hello" > /data/local/tmp/file.test
iptables -P FORWARD DROP
However, we are not seeing the expected output after boot.The string "hello" is not seen in file.test
We have also run setenforce 0, but it hasn’t made any difference.
please share step for running script after boot or after file system is up
 #ANDROID14
ラベル(2)
2,213件の閲覧回数
AldoG
Your init.rc seems correct, did you give your script the needed permission to write a file?
Which init.rc file are you modifying?
Also, did you rebuild your android image after the modifications?
Best regards/Saludos,
Aldo.
