How to show how much memory the VPU uses
erlend_eriksen
I need to decide how much memory to reserve for the VPU on my i.MX6Q. Therefore, I would like to see how much of the reserved memory it actually uses. Is there a way to check this?
Labels (3)
joanxie
you can use tools like "Antutu" or you can debug vpu source code to get the memory allocation, refer to the vpu_alloc_dam_buffer function in the mxc_vpu.c, if you need to know how much cma, you can refer to the imx6q.dtsi:
reserved-memory {
#address-cells = <1>;
#size-cells = <1>;
ranges;
/* global autoconfigured region for contiguous allocations */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x14000000>;
linux,cma-default;
