How to show how much memory the VPU uses
973 次查看
erlend_eriksen
I need to decide how much memory to reserve for the VPU on my i.MX6Q. Therefore, I would like to see how much of the reserved memory it actually uses. Is there a way to check this?
标签 (3)
903 次查看
joanxie
you can use tools like "Antutu" or you can debug vpu source code to get the memory allocation, refer to the vpu_alloc_dam_buffer function in the mxc_vpu.c, if you need to know how much cma, you can refer to the imx6q.dtsi:
reserved-memory {
#address-cells = <1>;
#size-cells = <1>;
ranges;
/* global autoconfigured region for contiguous allocations */
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x14000000>;
linux,cma-default;
