How to run SABRE i.MX6Q on Android emulator
1,662 次查看
kengoonoyama
I was trying to run SABRE i.MX6Q BSP and Android framework on Android emulator.
(SABRE Board for Smart Devices Based on the i.MX 6 Series Product Summary Page)
It has succeeded to compile all of the source codes, BSP and Android framework.
Then I've copied zImage as kernel.img, ramdisk.img, userdata.img and system.img.
And launched it by the following command on Ubuntu linux.
$ emulator -kernel $ANDROID_IMG/kernel.img -ramdisk $ANDROID_IMG/ramdisk.img -sysdir $ANDROID_IMG -data $ANDROID_IMG/userdata.img -show-kernel -debug-init -verbose
Emulator window appeared but it was blacked out forever.
Is it possible to launch SABRE i.MX6Q BSP and their Android framework on Android emulator?
If possible, is there tips for it? Or is there an alternative way to do emulation?
Thank you,
Kengo Onoyama
1,314 次查看
daiane_angolini
I have never tested it myself, but I think it would work (I´m not sure regarding 3D/2D acceleration, but it would be a second step anyway).
When I worked with android emulator, one step for the procedure was create the rootfs image, and change the init.rc in order to load the emulator. Did you make any change?
Are you able to see the log? Please, share.
1,314 次查看
karina_valencia
NXP Apps Support
NXP Apps Support
No response  from customer. Assumed this  was answered.
